correct way to install brake light switch? - Ford Truck Enthusiasts Forums
1966 - 1977 Early Broncos SPONSORED BY:
Old 10-30-2004, 08:50 PM
broncofl broncofl is offline
broncofl is starting off with a positive reputation.
Question correct way to install brake light switch?
I have had problems getting my brake lights to work when depressing the brake pedal. I have had to resort to adding a spring tie wrapped to the switch and streched to the underside of the dash to keep tension on the switch. I have never seen the correct way to attach the brake switch with the correct bushing to make it work as soon as I touch the brake pedal. Can anyone show me the correct assembly of the brake rod and switch assembly? Thanks
Broncofl
Old 11-23-2004, 01:35 PM
charlesecarter charlesecarter is offline
charlesecarter is starting off with a positive reputation.
It should have a small pin that goes through a hole into the pedal and mounts into it and is held in with a cotter key.
No brake lights on a 1967 f100 camper special gearhed1971 1967 - 1972 F-100 & Larger F-Series Trucks 19 07-22-2015 03:58 PM
Brake Light Switch Issue Technoblake 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 06-08-2014 06:09 PM
74 to 78 manual pedal assembly ??? co425 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-01-2013 08:04 PM
Brake light wiring issues 78 F-350 quadrazer 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-23-2012 11:54 AM
Turn signal wiring and brake light ?'s Andy63 1961 - 1966 F-100 & Larger F-Series Trucks 10 03-21-2003 11:59 PM
Tags
1987, 1996, 66, 87, brake, bronco, f250, f350, ford, ii, install, installing, light, pedal, replace, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
