94 4.9 Oil Pan Gasket Slipping
I am going to have to replace the oil pan gasket on my '94 F150 300 Six. The gasket is slipping out from between the block and oil pan. I have read some threads where I may have to jack up the engine. I want to do it right , but I also want to do it the easiest way.
What is the best top of the line oil pan gasket?
Thanks,
Smittyd
Thanks,
Smittyd
Fel Pro sells a molded one piece gasket called Permadry. I'm not sure if they make it for the 300 though. It may be more money than a multi piece, but I think the difference is well worth the money. I'm sure Victor makes a similar type gasket. IMO stick to a good quality brand, don't go for the low buck gasket. A few dollars saved will be no bargain if you have to do it over again.
Also, don't over torque the pan bolts.
SmittyD
04-09-2005 07:54 AM
