Code P 133
Old 10-30-2004, 06:37 PM
johnappleseed's Avatar
johnappleseed
johnappleseed is offline
Code P 133
Does anyone have any suggestions for this code? I am guessing it has something to do with my fuel system since i am getting very low mileage. any help would be appreciated. thanks
btw - '98 4.0L
Old 10-30-2004, 09:38 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
P0133 is "O2 sensor circuit slow response; bank 1 sensor 1". Slow response usually indicates the O2 sensor is going bad. Bank 1 sensor 1 is the first sensor after the manifold on the passenger side.
Old 10-31-2004, 03:43 AM
johnappleseed
thank you
i will check that out immediately. thanks for the information loneranger.
Old 10-31-2004, 11:25 AM
johnappleseed
well, i went around town pricing o2 sensors today. by the time i had made to the 3rd auto parts store, the cel disappeared. is this normal? i assume that the sensor is still going bad. should i wait for the light to come on one more time before i replace? thanks for your help
Old 10-31-2004, 04:52 PM
thelonerangerxlt
John, I've had that happen before. The MIL would come on and then go off again, usually when driving on the interstate, and then changing to in-town driving. It means the O2 sensor is going bad (or getting covered with carbon), and will fail eventually.
You can change it at your leisure. I'd pick a nice sunny fall day, rather than wait until it gets cold. It'll probably run a lot better and get better mpg with a new one.....
Old 10-31-2004, 04:58 PM
thelonerangerxlt
sorry, double post
Last edited by thelonerangerxlt; 10-31-2004 at 05:00 PM. Reason: double post, sorry
Old 10-31-2004, 10:22 PM
johnappleseed
thanks for the advice...i will replace it soon. it's starting to get cold up here in the northwest - need good mpg to get to the ski hills!!! thanks loneranger
Steve369
1997-2006 Expedition & Navigator
02-04-2016 10:25 AM
j66b
10-01-2014 02:38 PM
cablemaster
09-20-2004 05:24 PM
ranger pat
Paint & Bodywork
02-02-2004 12:26 AM
cinnpass
10-02-2002 12:44 PM
Quick Reply: Code P 133
