Code P 133 - Ford Truck Enthusiasts Forums
Code P 133
Old 10-30-2004, 07:37 PM
johnappleseed johnappleseed is offline
johnappleseed is starting off with a positive reputation.
Code P 133
Does anyone have any suggestions for this code? I am guessing it has something to do with my fuel system since i am getting very low mileage. any help would be appreciated. thanks
btw - '98 4.0L
Old 10-30-2004, 10:38 PM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
P0133 is "O2 sensor circuit slow response; bank 1 sensor 1". Slow response usually indicates the O2 sensor is going bad. Bank 1 sensor 1 is the first sensor after the manifold on the passenger side.
Old 10-31-2004, 04:43 AM
thank you
i will check that out immediately. thanks for the information loneranger.
Old 10-31-2004, 12:25 PM
well, i went around town pricing o2 sensors today. by the time i had made to the 3rd auto parts store, the cel disappeared. is this normal? i assume that the sensor is still going bad. should i wait for the light to come on one more time before i replace? thanks for your help
Old 10-31-2004, 05:52 PM
John, I've had that happen before. The MIL would come on and then go off again, usually when driving on the interstate, and then changing to in-town driving. It means the O2 sensor is going bad (or getting covered with carbon), and will fail eventually.
You can change it at your leisure. I'd pick a nice sunny fall day, rather than wait until it gets cold. It'll probably run a lot better and get better mpg with a new one.....
Old 10-31-2004, 05:58 PM
sorry, double post
Last edited by thelonerangerxlt; 10-31-2004 at 06:00 PM. Reason: double post, sorry
Old 10-31-2004, 11:22 PM
thanks for the advice...i will replace it soon. it's starting to get cold up here in the northwest - need good mpg to get to the ski hills!!! thanks loneranger
2006 Expedition airbag code 34 Steve369 1997-2006 Expedition & Navigator 6 02-04-2016 11:25 AM
Option Code j66b 1987 - 1996 F150 & Larger F-Series Trucks 1 10-01-2014 03:38 PM
Error Code 332. cablemaster Explorer, Sport Trac, Mountaineer & Aviator 12 09-20-2004 06:24 PM
Grabber Blue Paint Code ranger pat Paint & Bodywork 4 02-02-2004 01:26 AM
1993 F-150 codes cinnpass 1987 - 1996 F150 & Larger F-Series Trucks 2 10-02-2002 01:44 PM
Tags
133, 2002, 94, 98, aerostar, code, codes, explorer, f150, ford, p133, sport, taurus, trac, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
