Question about the stock air intake.
OK, I'm looking at modifying the stock cold air intake. It has a tube from the driver side fender well to the air filter box. Along that tube are what appear to be 3 "offshoots" of the tube that the air seems to go into waffle shaped boxs (I know that is not very clear so you might need to go look at it). What are those offshoots for? are they filters or some sort of noise reduction. If you were to cut off those things and plug the holes, what impact would it make to air intake?
The waffle shaped plastic boxes are for sound reduction on the intake side. They are supposed to do the same thing as baffles in a muffler, and reflect the sound waves back so they cancel each other out.
Don't know if any cutting off and plugging would effect anything, but probably would be hard to plug the holes.
I think they are just baffles to reduce intake noise. That is one reason the aftermarket intake kits are a bit noisier (but more efficient). I guess you could cut them off and plug the holes...but I would probably fork out the $$ and get an aftermarket setup. I don't know that altering the factory piece would really yield much HP. If price is an issue, you may be able to fabricate your own somehow.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
I took the big intake tube off my truck and drove it around town one time to see the sound difference. There wasnt one. It didnt sound any different with that mig hunky tube off. So this means that the sound restriction is in the filter box housing.
Just figured i would share that with you.
That's strange that those baffles don't effect intake sound. Sometimes I think those Ford Engineers do things like this just to confuse us.
Anyway, if Toreador (or anyone) modifies their intake by cutting those things off, please let us know the results. Free HP is always a good thing to find.
Good luck and keep us posted!
Most all cars that I have worked on have the Taper at the enterance of the intake tube.
And as for running a hose, I tried that on my 95' Grand Marquis. I cut the intake tube in half and pieced together some PVC pipes that ran behind my grill. I didnt notice any performance but MAYBE a little more MPG. Maybe. It could just be in my head.
I really miss that car. Had the JET chip in it, 4.10 LS in the rear, larger throttle body and throttle body spacer. Bosch 4+plugs and MSG ignition. (Forgot what kind). It was would flat out fly down the highway. Made this F150 feel like a 4 banger.
Originally Posted by SteveVFX4
I'm also wondering if you could run some type of hose from the lower bumper opening up to the inner fenderwell into the stock intake tube for increased air inflow? Anyone try that? That would simulate a "cold-air" type setup.
It looks like a similar setup would work on the newer trucks, if only someone made one.
