Trailer wiring help - 1994 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-29-2004, 07:40 PM
Firescooby Firescooby is offline
Firescooby is starting off with a positive reputation.
Trying to help my neighbor wire a trailer light plug to his 1994 Ford Ranger. It has the amber turn signals and we're having trouble.
Can anyone provide what wire goes where? We've got the white grounded and we've tried just about everything with the yellow, green and brown wires.
ANY help would be greatly appreciated. They did not have the type where you just plug it into the wiring already. All they had was the plug with four wires that you must splice.
Thanks
Old 10-29-2004, 07:59 PM
Rocky J's Avatar
Rocky J Rocky J is offline
Rocky J is new and has a neutral reputation at this point.
You need the adapter in order to make the turn signals work. You cannot wire a 4 wire harness directly into the Ranger. You need to wire in the 5 wire plug and then use an adapter or else you need to find the plug-in for the Ranger wiring harness.
Old 10-29-2004, 08:10 PM
Help I M Stuck Help I M Stuck is offline
Help I M Stuck is starting off with a positive reputation.
you can tap the brown wire into one of the tag light wires..that will give you runing lights. You then need a test light to find out what is the wire for the left/right turn..i usually just take a tester or light bulb (rigged to llight up) and then a safety pin..with the ground on a ground..take the tail lamp off..with the safety pin..poke the wire to make contact..then connect the other wire from the tester or bulb to it..see if it lights when you press on the brake. If i remember yellow is left turn on trailer and green is right turn. It can be done..but remember when you do get it to work...you will need a new TURN SIGNAL FUSE ..it will be marked for trailer towing..if not your signals will blink really fast...and the factory fuse will burn out.
Old 10-29-2004, 08:19 PM
Rocky J's Avatar
But then the brake lights won't work on the trailer. He needs the adapter to tie the brake lights and turn signal lights into the same trailer bulb.
Old 10-29-2004, 08:20 PM
Thanks guys...he's gonna get the adapter.
Old 10-29-2004, 08:24 PM
Quote:
That's funny..my 86, 91, 93 and 96 Ranger all work.
Old 10-29-2004, 08:34 PM
Rocky J's Avatar
ummmm- no they don't. If you wired them all the way you described here, then you have turn signals but no brake lights on your trailer.
Scooby, good call getting the adapter. It's fast, easy and idiot proof. Also you don't need to cut or poke the weathercoating on any wires so you're less likely to have future wire corrosion.
Old 10-30-2004, 02:24 AM
seantx seantx is offline
seantx is starting off with a positive reputation.
Thumbs up
^^^^ Truth.
I just stopped by the Mart on the way home and picked up one of the adapters. ~$25. Kinda pricey, but I'll say that it took me 10 minutes to install and tuck cables out of the way and it works perfectly. Snap, snap and a few zip ties and it is done.
I'm pulling a 14' tandem axle flatbed next weekend. No worries about the wiring now.
04 Expedition - No trailer brake lights qpsdoll Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 3 06-13-2015 05:05 PM
1976 F100 - Fuses Blowing Carolina Razorback 1973 - 1979 F-100 & Larger F-Series Trucks 14 12-31-2013 02:16 PM
Which wire is the ground? Replacement mirror question Mr&MrsSchloofy 1999 to 2016 Super Duty 1 12-28-2013 10:13 PM
flywheel problems with my ranger. fordtruckgirl08 Ranger & B-Series 28 02-19-2010 07:56 AM
What's a PIP? cookie88 Bronco II 13 09-18-2007 06:31 PM
Tags
1994, 94, ford, fourwire, installing, ranger, trailer, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
