best carbed 4 cylinder for ranger? - Ford Truck Enthusiasts Forums
Old 10-29-2004, 12:52 AM
oldhalftons's Avatar
oldhalftons oldhalftons is offline
oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.oldhalftons has a good reputation on FTE.
what is the best carbed 4 cylinder to build for a 2wd ranger?
does the 2.0 or 2.3 have the most aftermarket support?
does any 4 cylinder have the same bellhousing pattern as the 2.8 V6
I'm kind of thinking about eventually putting together a mildy
built 4 cylinder, but I don't really have a starting point.
Old 10-29-2004, 08:05 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
There's more aftermarket interest in the 2.3.
The V6s may share the same bolt pattern on the bellhousing, but the starter is on the wrong side.
AL.
Old 10-31-2004, 10:38 PM
canzus canzus is offline
canzus is starting off with a positive reputation.
An early 2.3L from a Pinto or Mustang would be the
most sensible starting point, use either a Motorcraft
5200 2BBl carb, or adapt a holley 2100 to the manifold,
a tri-y header, a late model Ranger roller cam, 9:1
compression pistons, should be good for 130+HP...
SteveL
Old 11-02-2004, 01:00 PM
hotrodfeguy's Avatar
hotrodfeguy hotrodfeguy is offline
hotrodfeguy is starting off with a positive reputation.
Well
I dont know of any one as "best" in factory form they are all close.Prolly within 10 HP of each other in stock trim.I do think as said before that a larger than stock cam port polish and shave to 9.0 CR is all good.And also as posted try to make it all flow headers cat removal if you can in your area.If you have a carb set up already you have a AIR or smog pump.Get rid of it if you can.
Old 11-03-2004, 11:38 AM
by "best" I was really trying to get an idea of availability of aftermarket parts, and how common the engines are in stock form. the 2.3 looks like a pretty easy core to find and build.
Old 11-03-2004, 02:53 PM
yes
There is a bunch of stuff for it,mostly due to the mini stock racing and the use of it there.The 2.3L is very nice for aftermarket parts.Racer Walsh,Esslinger are two good ones.Also the turbo coupe T-bird and XR4TI make for great donor cars for turbo.200 HP is not that hard.
Old 11-05-2004, 01:49 PM
samickguy15 samickguy15 is offline
samickguy15 is starting off with a positive reputation.
2.3l
2.3L engine
9:1 or 10:1 compression
Roller cam
87 or later lower intake (Best flowing intake available)
header
Turbo-blue for the fuel!!! Love the smell of that stuff
Cylinder 4 misfire /back 2 lean code Mvenem 3.0L V6 0 01-18-2016 05:59 PM
Removing Manual Door Lock Cylinder 94_Ford_Ranger Ranger & B-Series 1 10-02-2015 10:57 PM
Ranger 10" Brake Link Pins aj197816134 Ranger & B-Series 3 05-03-2014 02:59 PM
master cylinder 1994 ranger ford Ranger & B-Series 6 03-24-2014 06:28 PM
Replacing Ranger 2.9 rj2sewalot Engine Swaps 17 02-06-2007 08:16 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
biggest, carbed, cyl, cylinder, engine, forum, pattern, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
