PCV valves for E/F-series?
Old 10-28-2004, 07:40 PM
metrovic's Avatar
metrovic
metrovic is offline
Are PCV valves used on late model trucks with the 5.4L SOHC V8?
I popped the doghouse for my 2003 E-250 w/ the gas 5.4L SOHC V8 and could not locate a PCV valve.
Ford's computer lists EV-238 as the Motorcraft replacement valve, but the usual spots on the cam covers didn't show signs of a grommet for the PCV.
Did Ford switch to a fixed orifice instead of a PCV?
Old 10-29-2004, 05:55 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It is in the passenger side valve cover about 1/2 way back. The hose is probably covered with a foam type insulation. The tubing goes from the valvecover to the elbow on the intake that the throttlebody is bolted to in the rear.
wrangler2520
1999 to 2016 Super Duty
03-20-2020 06:20 PM
rugateer
11-18-2014 12:31 PM
CurtSD
Modular V8 (4.6L, 5.4L)
08-26-2014 04:17 PM
jason3482
2004 - 2008 F150
11-28-2011 11:35 AM
Jbrown8988
02-01-2010 09:02 AM
Quick Reply: PCV valves for E/F-series?
