battery won't stay charged - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-11-2002, 07:36 PM
General_Lee General_Lee is offline
General_Lee is starting off with a positive reputation.
Post battery won't stay charged
I can't seem to keep the battery charged in my 90' Ford Ranger. I've got a brand new battery and had the alternator checked and they said that was fine. I'll drive it around for about a half hour and if it sits for a day it won't start. I guess something is draining the battery, but for what and where do I look? Some help would be appreciated. Thanks.
Old 09-11-2002, 11:34 PM
Rand Rand is offline
Rand is starting off with a positive reputation.
[updated:LAST EDITED ON 11-Sep-02 AT 11:35 PM (EST)]You might have a light on somewhere. Maybe in the glove box or something, thats what it was on my old car. perhaps something similar. You can check by getting an amp meter and pulling the fuses from the fuse box and use the amp meter to see if there is any current draw. when you find what fuse it is.. you will have an idea if something has a short in it. It could also be a wire somewhere in the truck grounding to the frame.
NOTE: on some fuses there will be a small draw.. ex clock on radio etc. Oh and just pull the fuses one at a time if you are going to do it that way you dont get em confused.
Old 09-12-2002, 03:39 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Just a little more, you connect the amp meter by disconnecting the neg battery cable and putting the amp meter in line there, don't try to start the truck with it there.
Old 09-15-2002, 03:11 AM
Right Ken,
I should have mentioned doing that first, I guess I was half asleep after 16 hours at work .
Rand
Old 09-17-2002, 05:29 PM
tomf52 tomf52 is offline
tomf52 is starting off with a positive reputation.
Disconnevct the output wire from yhe altenator and see if the battery still dies after sitting for the same period of time. If it does not die, your altenator is the cause. A bad diode will current drain back to the altenator and drain the bat,. Perhaps they did not do a diode test when they checked your alt.
Old 09-20-2002, 09:29 PM
Lhyzer Lhyzer is offline
Lhyzer is starting off with a positive reputation.
Check your fuel pump relay. Had the same problem with my 91 Ranger and the relay went bad. Stuck on and ran the battery down .
Old 09-21-2002, 10:42 AM
Critterhunter Critterhunter is offline
Critterhunter is starting off with a positive reputation.
Battery won't charge Jordan Edwards 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-06-2016 10:15 PM
charging battery question omni Electrical Systems/Wiring 8 11-18-2014 06:28 PM
Battery dash light 79_250RangerLariat 1994.5 - 1997 7.3L Power Stroke Diesel 14 05-05-2013 10:07 AM
Need help! Battery won't stay charged. 19-F250-78 1973 - 1979 F-100 & Larger F-Series Trucks 15 11-04-2012 08:57 AM
How to load test batteries? palaka 6.0L Power Stroke Diesel 5 11-30-2009 07:55 AM
Tags
04, 1001, 2005, 73, battery, charged, escape, expedition, f150, ford, ranchero, ranger, stay, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
