F350 Front Tire Wear - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-22-2014, 06:25 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
Old 10-28-2004, 11:37 AM
01screw 01screw is offline
01screw is starting off with a positive reputation.
Hey there, I'm now driving a 04 F350 Dually. The front tires needed to be replaced at 15K miles under warranty due to alignment problems. Now the second set of fronts, with only 9K miles are wearing to the point of needing replacement because the steering wheel is starting to shake again. I was told by one dealer that it's because I tow, that was the first dealer that I went to the first time the tires were replaced, which I think is BS, and the other dealer said all F350 dually's wear front tires out quickly, but 9,000 miles? Anybody have the same problem. Thanks
Old 10-28-2004, 02:24 PM
moebdick's Avatar
moebdick moebdick is offline
moebdick is starting off with a positive reputation.
Even a middle-of-road tire ought to go more than 9K miles. Shaking steering wheel? Sounds like you still have front end issues to me. What was done to "align" it before? What kind of tires are they? 2x4 or 4x4? What are you towing?
Old 10-28-2004, 02:52 PM
I'm running General Ameritracs which the truck came with from the factory originally. The first dealer I went said there was nothing wrong with the alignment and and the irregular front tire wear was do to towing. I tow a 28' tow hauler that when fully loaded weighs around 9,000 lbs. This is the same trailer I towed with my F150 Supercrew (very carefully) with no irregular wear after 36,000 miles so I didn't believe that. The second dealer I took it to the next day said that there was an alignment issue and it was corrected and the tires were replaced under warranty. Now the steering wheel is starting to shake mildy now which just started and the irregular wear is starting to show. The second dealer told me that it's "just the way it is" with a dually.
Old 10-28-2004, 08:18 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Front tire wear on a dually is not normal, I would call the Ford Customer service line and explain your problem, they will find a dealer that knows how to align the front end. Not all shops can handle a dually on there machine.
Denny
Old 10-29-2004, 09:58 AM
phil350 phil350 is offline
phil350 is starting off with a positive reputation.
My fronts needed replacement on my at DRW at 27k when I traded it in. I think it was because rotating was difficult and I did not do. I towed a lot. The 9k seems rediculous and indicitve of some other probelm to me.
Old 10-29-2004, 10:40 AM
Jeansbond Jeansbond is offline
Jeansbond is starting off with a positive reputation.
O1Screw... I am a new user of a 05 F350 SRW... so I can't speak from any experience about the specific vehicle... but I was for many years a brake and suspension mechanic. Generically, there is no reason for your inordinate tire wear, and assuming you're loading the rig properly with your towing configuration, the wear while towing should be little different than otherwise. Alignment, as has been noted above, is critical to proper wear. Also make sure all links, connections, bushings, ball jounts, tie rod ends, etc., are within spec... tight and with no more vertical and lateral play than factory tolerances. The amount of "toe-in" is the alignment spec most affecting tire wear, which if off will cause wear on the inside or outside edges with out of spec toe out or toe in, respectively. Next the "camber" (tilt of wheel/tire assembly off vertical) is impactive, but also generally causes wear on the inside or outside of the tire depending on out of spec negative (tire leaning in at top) or positive (tire leaning out at top), respectively. Because you also have front wheel shaking, which can be caused by out of spec "castor" (this is the angle of the axis upon which the assembly rotates when turning either way from straight ahead, much like the axis formed by the forward rake of a motorcycle front fork).
Most often, though, wheel shake is caused by imbalance of the tire/wheel assembly... up and down shake from "static" imbalance, where one side of the unit will fall to the bottom if left to it's own equilibrium when suspended on a freely moving axle... and side to side shake from "dynamic" imbalance (the correction of which is often marketed as "high speed balancing"). Visualize this imbalance condition by thinking of a tire/wheel assembly with a chunk of lead the size of a brick at one spot on the outside sidewall. As the tire rotates, the brick tries to follow the center line of rotation, oscillating to the left when at the front half of rotation, and to the right when at the rear half of rotation, thereby causing the steering wheel to go left and right at the same frequency as that of the rotation.
Lastly, a more obscure cause of your problem might be due to "radial run-out" (commonly called "out of round") of one or both of your tire/wheel units. Since the problem has persisted through more than one set of tires, I'd look closely at the wheels. This problem causes uneven tire wear, particularly cupping, can cause the same shaking as both static and dynamic imbalance, and gets worse as time goes on due to the fact that the most wear on a tire occurs at the point of the tire's smallest radius.
Hope this gives you a little help as you play Sherlock Holmes to find the problem.
Vic
Old 10-29-2004, 06:12 PM
biljo99 biljo99 is offline
biljo99 is starting off with a positive reputation.
Quote:
I've got just over 20,000 "towing" miles on my 2003 F350 dually and tires don't look like they've been hardly worn. I did rotate them all at 18000 miles.
Old 10-30-2004, 06:33 AM
SRD4X4 SRD4X4 is offline
SRD4X4 is starting off with a positive reputation.
I do alot of Alignments for a local dealer because there machine can't do crew cabs or dually's. Have found that 99 percent of all new trucks have between 1/4 to 3/8'' too much toe-in from factory.See alot of tires worn-out in 15-18,000 miles(6-8 a week) . Most are from never rotating and underinflation.Should rotate every 5-6 k. and run as much air as poss.,65-70 psi. atleast in a 10 ply tire and 55-60 in an 8 ply. if not max which should be 65 psi in an 8, and 80 in a 10 ply.this will cut down on flex in tire and help eliminate alot of "cupping" or "heel-toe" wear.
Old 02-17-2011, 10:36 AM
dillehay's Avatar
dillehay dillehay is offline
dillehay is starting off with a positive reputation.
SRD4X4 what shop do you work for? I am near you and need my 2003 F350 front end checked out?
Old 02-17-2011, 10:49 AM
99f350sd 99f350sd is online now
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
My thought are too much toe in as camber being off doesn't wear fast. I think the spec's are almost straight ahead on these trucks..
Dick
Old 09-21-2012, 03:31 PM
GeeStooks GeeStooks is offline
GeeStooks is starting off with a positive reputation.
Hello all, This is my first posting. I have an 02 F350 4WD And I also have the alignment problem. I do tow some but mainly use the truck as a daily driver. My truck has been on the alignment rack twice just for them to say that My truck was fine. One of them went as far as to say that if I installed the steel wheels that my problem would go away. I keep my air pressures on 80psi on 10pr tires. And rotate and balance every 5000 mi.
Now I do have a question. would I be able to go from the 170mm bolt pattern and go to the 200mm with the factory aluminum 17" to eliminate some of this? Or am I wasting a bunch of time and money?
Old 09-21-2012, 06:04 PM
02TB250's Avatar
02TB250 02TB250 is offline
02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.
This would not be possible as far as i know without changing the actual hubs on the truck. The bolt pattern has nothing to do with rim size.
Old 09-21-2012, 09:23 PM
Yes I thought about changing diffs that has the 200mm bolt pattern. Ford does have the 17" wheels in both patterns and I have an opportunity to make a purchase of a new set of take offs from a local dealer. But I donot want to go through the trouble if it will not solve the problem. I am still running the factory 16" aluminum wheels. If the alignment guys would shoot me the alignment specs that they go by vs the factory's way that would be helpful too. Thank you for your reply.
Old 09-21-2012, 09:39 PM
I have 55 in front and 45 in the rear unless loaded. 80 psi is way too much air in the tires. Must ride like crap. The wheels you have on the truck need to have the correct backspacing etc for that truck. Other than that the 99-04's don't wear tires fast usually..Make sure you have good shocks.
Dick
Old 09-22-2012, 08:12 AM
Thanks Dick, I see that you are not too far from Waterbury, I have been at GMCR In TN for 4 years.
I have 10ply tires on my truck max out at 80psi. If they go down to @ 65psi Starts to look like a car tire does @15psi. Really low. Everything as far as the truck is concerned is still all factory. no suspension mods at all. I will revisit my shocks as you suggested. My truck is a long bed 4door dually ride is not to bad.
Matching tires? unibody62 Offroad & 4x4 6 11-22-2016 05:39 PM
Front brakes not working 100% Boundertom 1999 to 2016 Super Duty 16 09-11-2016 07:47 PM
Uneven tire wear and everything is fine? TexasJackDaniels 6.7L Power Stroke Diesel 24 08-23-2016 01:42 PM
Rt front tire outer wear Mike Bartlett 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-04-2011 05:28 PM
dually tire wear someday Brakes, Steering, Suspension, Tires, & Wheels 10 10-30-2005 03:07 PM
Tags
1999, 2000, 35, axle, cupping, dually, f250, f350, ford, front, inside, shaking, tire, tires, wearing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
