89 Ford Bronco Rear Window Switch problems - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 10-27-2004, 06:43 PM
krantzfamily krantzfamily is offline
krantzfamily is starting off with a positive reputation.
Hi all
I have an 89 Bronco and the switch to roll the rear window down doesn't work. I can roll the window down with the key but we lost the key and until I can get replacement I need to figure out how to roll down the window with the switch.
We checked schematics in a haynes book but they are way off. All I can say is that the fuse is fine.
Does anyone have suggestions what to check?
Thank you!
Old 10-27-2004, 07:24 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan MinnManBroncoFan is offline
MinnManBroncoFan is starting off with a positive reputation.
Take off the back panel to the tailgate take a flash light and look at were the key switch comes into the tailgate.
When the key is turned a lever hits the button to make the window go up or down depending which way you turn the key.
You might have to take off the lever to push the button to make the window go down.
If you push the button for down and the window won't go try hot wiring the motor with 12v.
If motor still won't go motor is bad I never seen a window motor go bad yet.
After you take off lever from window lock you can take off spring clamp that holds in lock and take it ot a locksmith to have a new key made.
For switch bypass it. It is just a rocker switch If you bypass it and window works switch is bad.
First take off tailgate cover and make sure motor works.
Old 10-31-2004, 09:12 PM
mike_i's Avatar
mike_i mike_i is offline
mike_i is starting off with a positive reputation.
Take the switch out of the dash and take it apart. Chances are that the problem with the switch is that from the contacts arcing (which is normal), they aren't making good contact anymore. This happens alot on door switches for power windows and power door locks. I had the ones in my '88 bronco and my '88 F-150 out 100 times. Take the switch apart and GENTLY file the contacts down with light sandpaper or a fine nail file until all the black arc marks are gone. Good as new.
window switch issues Krazyhorse93 1999 to 2016 Super Duty 1 10-14-2016 03:00 PM
tailgate safety button/sensor etc window stuck up Berardini2121 1978 - 1996 Big Bronco 2 06-22-2016 03:12 PM
Rear window switch? BxTCHIE1 1978 - 1996 Big Bronco 5 03-03-2011 12:35 AM
Window wont roll down? Learn from me v8xploder 1978 - 1996 Big Bronco 1 04-28-2009 10:53 AM
rear window electric problems glu252 1978 - 1996 Big Bronco 1 06-19-2005 12:29 PM
Tags
89, bronco, ford, inside, issues, rear, stuck, switch, tailgate, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
