61-66 F100 Registry
#151
Not Putt, but
You will need the 428 flywheel/flexplate and balancer as it is externally balanced. Everything else should bolt up just fine.
Originally Posted by ford truck guy
Putt,
I'm buying a 66' F100 that I'm turning into a street rod. Looking at a 460 block and also talking to a builder about a 427. Since you have the FE bolck, did you have any difficulties making the switch to the 428? I'm looking for a drum/disc conversion kit. Any suggestions? Thanks Ford truck Guy
#153
1965, with a '63 front clip;
F100;
Styleside, short box;
390, w/ headers, 780 Holley, PI-spec'd cam;
T-18 4-speed, 3/4-T rear leaf springs;
2WD w/ BFG T/A 6-ply radials.
My seasonal-use truck. Primarily used as my "tow truck" pulling a car hauler-type flat trailer loaded with my '69 Mach I drag race car.
F100;
#154
Year: 1966
Model: F100
Vin:f10ACXXXXXX
Step or stylesid:Styleside
Engine:Inline 6 240
Trans: 3 on the tree
2x or 4x: 2x
Year: 1966
Model: M100
Vin:M10??XXXXXX
Engine: 1970? V8 302
Trans: 4 spd manual
2x or 4x: 2x
Hopefully a 65 M100 with inline 6 and 3 on the tree comin, styleside
Model: F100
Vin:f10ACXXXXXX
Engine:Inline 6 240
2x or 4x: 2x
Year: 1966
Model: M100
Vin:M10??XXXXXX
Trans: 4 spd manual
2x or 4x: 2x
#155
#159
1966
F-250
F25YR789169
Styleside long bed
427 (was 352)
FMX trans (cast iron)
2X
Mean old bitch also known as the "Green Flash", or the "NASCAR Shop Truck"
https://www.ford-trucks.com/article/...Shoptruck.html
Regards,
MustangDon
www.mustangdon.com
F-250
F25YR789169
Styleside long bed
427 (was 352)
2X
Regards,
MustangDon
www.mustangdon.com
#163
#165
1960 F100
VIN: F10COX54367
Styleside - Short box
Y-block
T-98
Plan to restore to Like New (My retirement project)
1963 F100
Uni - Short box
223
4-spd
Plan to convert to daily driver with probably a 302 and automatic
1963 F600
Grain box w/ Hoist
Y-Block
4-spd w/2spd axle
Using as is but will probably salvage parts and scrap truck at some point
1965 F250
Camper Special (With 64 front clip and inherent incompatability of wiring etc.)
Styleside Long box (Believe it left the factory as a chassis cab)
FE Engine (Rebuilt one w/4bbl is in the barn on engine stand)
T-18 (Was a Cruiseamatic)
Current project to use as 'around the farm' truck and trailer puller
1975 F100
302
4 spd
Parts truck
My wife says that for every truck I get she is going to get another horse so I am trying to control myself
VIN: F10COX54367
Y-block
T-98
1963 F100
Uni - Short box
223
4-spd
1963 F600
Grain box w/ Hoist
Y-Block
4-spd w/2spd axle
1965 F250
1975 F100
302
4 spd
Parts truck
