Xtra vision bulbs for F150 now available
replied to your email. Good luck man. It took 2 weeks for me to get them but that was the week they came out. You should be able to get them quicker. Took me about 30 minutes to install the headlights. They were not as easy as the fog lights. Had to remove the headlight bolts to get to the back. Its in the truck manual and was not hard, just took a few minutes. Also, make sure when you remove the old bulbs you take out the old rubber gasket (its red). Mine stayed in there and when I put the new bulbs in I couldn't figure out why they were too hard to go in. Turned out to be that there were two rubber gaskets (one from the old bulb and one from the new).
http://www.danielsternlighting.com/t...nversions.html
You guy's should read this info before you start screwing around with these lights.. What you are buying may not be what you want...
Originally Posted by Dunk
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
the stock lights are ok but i wouldn't go as far as incredible. the lights on my wifes liberty are much better than mine. i will have to say that the silverstars in the fogs made a vast improvement over stock. they shine farther and wider and that helps alot when you have to drive alot of curvy country roads with no street lights and lots of deer. they were well worth the $40.
Phantomwraith
2015 - 2020 F150
07-27-2015 02:29 PM
