Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-27-2004, 03:14 PM
love2shift love2shift is offline
Garage is empty, add now
love2shift is starting off with a positive reputation.
more power in my 2.3L
I just got a 5 speed 97' Ford Ranger with a 2.3L engine in it. I was wondering how to get more horsepower and performance out of my truck. What can I do to my ranger to make it go faster?
  #2 (permalink)
Old 10-28-2004, 01:54 PM
RangerX's Avatar
RangerX RangerX is offline
RangerX is starting off with a positive reputation.
Intake Exhaust (together, good difference) electric fan, chip.. fficeffice" />>>
other things.. mine never had A/C and my Power steering exploded, so i removed it.. this made a really big difference..>>
there’s other things, but it gets expensive after those>>
Intake Exhaust (together, good difference) electric fan, chip.. >>
OH and making sure your breaks are not binding and the trans is changed regularly.....
  #3 (permalink)
Old 11-26-2004, 04:18 PM
bigrngr666 bigrngr666 is offline
bigrngr666 is starting off with a positive reputation.
i took the baffleout on my intake i replaced it with 3in exhaust tubing and did my exhaust. it made a noticeable differance
  #4 (permalink)
Old 12-02-2004, 01:28 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
First off, start with a good tune up. Plugs, wires, air filter, etc.
You can remove the rubber silencer that is attached the airbox that goes into the inner fender. I'm not sure if it is really worth much power, but it does change the sound of the engine a bit. I wouldn't waste your money on so called "cold air intakes" unless you just want to dress up the engine compartment a bit. Most of them end up drawing in more hot air because they leave the filter completely exposed to the hotter underhood air.
As mentioned, a good exhaust system will help out. Don't go overboard on the size of the piping, you'll probably end up killing your low end torque if you use anything over 2.25" with this motor. Have an exhaust shop make a new intermediate pipe sans converter for daily driving, then bolt the factory pipe if/when you have to get an emissions test.
Dual plug heads have very small intake and exhaust ports compared to other 2.3L heads, so don't waste your time and money on larger throttle bodies and the like until you open up the head and intake, which present a far greater bottleneck than the throttle body on a stock motor. If you are so inclined, a mild port/polish job on the heads and intake would probably work wonders on these trucks. I'm not sure if it is doable, but I'm awfully tempted to swap out the 2 plug head on my truck for an earlier single plug head from something like a turbo coupe or 87-88 Mustang. I guess the EEC won't get upset about there only being one operable coil pack. It would certainly make changing the plugs easier!!
__________________
2012 F-150 Lariat, SCrew, EcoBoost, 157"WB, 3.73 axle
  #5 (permalink)
Old 12-20-2004, 10:12 PM
R.W.F. R.W.F. is offline
R.W.F. is starting off with a positive reputation.
I think B&M makes a blower for the 2.3
  #6 (permalink)
Old 05-21-2005, 11:46 PM
Jent Jent is offline
Jent is starting off with a positive reputation.
hey, i wanted to bring the subject back up because i had the same question. now im running the same system as teh guy who started the post, but my engine has almost 100k on it, and ive been told to swap out the engine or rebuild the stock parts rather than get anything preformance. how accurate is this? what do u guys suggest?
  #7 (permalink)
Old 05-22-2005, 10:36 AM
pmeisel pmeisel is offline
pmeisel is starting off with a positive reputation.
Quote:
at 100K I would not put a lot of money in without at least checking to see if the rings and bearings are ok. Run a compression check or pull the heads and look at the cylinders. But I woul go ahead and rework that engine.....
__________________
Paul
  #8 (permalink)
Old 05-23-2005, 06:24 AM
91 Ranger Turbo 91 Ranger Turbo is offline
91 Ranger Turbo is starting off with a positive reputation.
I would do a motor swap. 2.3 turbo is not a bad job. you can do it in a weekend taking your time.
  #9 (permalink)
Old 07-06-2005, 08:48 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite Samsonitesamsonite is offline
Samsonitesamsonite is starting off with a positive reputation.
Quote:
Is this true? wow i oculd get dangerous with this..... Muwhahaha.... who has any info on this?
__________________
RIP all my fords.
  #10 (permalink)
Old 07-14-2005, 03:33 PM
88treadbrite_150_4spd 88treadbrite_150_4spd is offline
88treadbrite_150_4spd is starting off with a positive reputation.
do the turbo swap it is well worth the power
  #11 (permalink)
Old 07-22-2005, 09:18 PM
I've never heard of a blower for the 2.3L, unless it is for the older carbureted motors.
I think a weekend is kinda optimistic for doing an entire engine swap unless you're putting in 10-12 hour days and have a couple of helpers. It took me nearly all day long just to get the engine out of my SVO by myself.
__________________
  #12 (permalink)
Old 07-23-2005, 12:58 AM
i can have to motor out of my ranger in 45 min or less
__________________
RIP all my fords.
  #13 (permalink)
Old 07-25-2005, 01:28 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
The only things I have ever heard of aftermarket forced induction for the 2.3L (as in the Lima 2.3L) have been of questionable quality at best from basically back-alley hole in the wall types.
  #14 (permalink)
Old 07-25-2005, 11:00 PM
ACTUALLY, eaton makes a blower for the 2.3.
__________________
RIP all my fords.
  #15 (permalink)
Old 11-02-2005, 07:30 PM
buckeyes903 buckeyes903 is offline
buckeyes903 is starting off with a positive reputation.
I bought a high flow intake for my 94 2.3 and a modified Mass Airflow Sensor, but whenever i put on the intake the truck bogs really bad at low rpms and i don't know why, i also have a high flow cat, and a delta 40 flomaster exhaust, not sure on the size, but can anyone help me with this?
Tags
23, 23l, add, air, crosse, engine, engines, ford, high, la, performance, power, svo, turbo, wi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
