Swap cd-6 for Factory Navigation
There are a lot of functions that needs to be pre-wired in order for the navigation system to work, wo you can take advantage of this very expensive radio, like the GPS antenna and some other sensors. Besides, this radios does not use the same connector type that the CD6. You can try making yourself (or ask one service center to do it) a harness converter to connect only the features you need for navigation and for sure it will work.
It can be done by a experience installer. My 03 xlt with 6 disc has been converted to lincoln dvd base touchscreen navigation system.It work great and look factory. The cd base navigation from ford will need new dash bezel,because it larger (2.5 din) than 6 cd radio.The possitive side is it selfcontain, and does not need external amp. All it needs is gps antenna and
cd map disc.
cd map disc.
USAF1A8
1997-2006 Expedition & Navigator
25
02-13-2017 07:21 PM
allanhilliard
01-13-2017 11:59 PM
konrad79
01-23-2015 07:16 PM
