95 302Bronco Radius Arm Bushing need help
i just replaced mine and i unbolted the radius arm bracket from the frame. the hard one was the drivers side, the bracket was riveted to the frame. so i had to cut off the rivets and then bolt the new bracket on. ( i had to special order that from the dealer, cost me $45.00) i don't think there is a way to do it with out unbolting the brackets though, if there is....I'm not aware of it! good luck.
You could unbolt the front axle, and the radius arms will pull right out. Some have gone to the extent of using a ratchet strap, unbolting the radius arm nuts at the bracket, and ratcheting the front axle forward until it was clear. I just removed the brackets myself. I had the same dilema, the driver's side was riveted on. I drilled out the rivets and used new GRADE 8 bolts to fasten it back to the frame. I think it took a 9/16 bit, and I didn't need a new bracket.
i bought the new bracket in advance, trying to play it safe. (the way my luck goes i could imagine getting it all apart and figure out i needed a new one when it was too late and had to drive the truck to work the next day.)
hey are the stainless steel bolts as good or better than the grade 8? my local hardware store was out of the grade 8, and the stainless steel i believe was labeled as 8.8? just wondering.
I had the rivets torched out when I upgraded my muffler at my local muffler shop. They didn't charge me for cutting the rivets.
Then I unbolted the brackets.
Replaced the rivets with Grade 8 bolts.
Be sure to get instructions (for the order in which they go in) when you purchase the bushings...
Should be an easy fix... 20-30 minutes each side... with a stretch in between sides...
Here is how I did mine, after finding this site. However, I used an air chisel instead of the torch method. By the way, the socket size was not 1 1/4. I believe it is 28 mm if I recall correctly.
http://www.off-road.com/ford/bigbroncos/tech/rad_arm/
That method described sounds alot easier than what i went through. i was using a cheap air chisel and it took forever!! i eventually ended up trying to drill out the rivets, and eventualy used a grinder to finish the job. The right tools make all the
difference.
(ps- i just figured out what "Ojosdestranger" meant, never thought it was in Spanish. I thought it was something to do with OJ Simpson, he drove a Bronco right?)
difference.
difference.
difference.
It means, Eyes of a Stranger... Got it from Queensryche from the Operation Mincrime concept album...
"People always turn away from the Eyes of a Stranger, Afraid to know what lies behind the start!"
A couple of follow up questions, as I am getting ready to tackle this one myself. What size/length grade 8 bolts did you use for this job. I believe there are six rivets but I am going to double check before I go to the parts store. Also, I have read of an issue with a spacer involved in the replacement of the bushings. Can any of you shed any light on that. I hate getting into a job and discovering that I need more parts.
