reverse lights don't work - Ford Truck Enthusiasts Forums
Old 10-27-2004, 10:28 AM
dsauka dsauka is offline
dsauka is starting off with a positive reputation.
On my 1979 Ford f150 custom the reverse lights no longer work. I checked the bulbs and they are fine. Checked the fuses and they are fine too. Wire running to rear taillights seem to be ok too. Not sure where else to look. Has anyone else had this problem? What else can I check?
Old 10-27-2004, 11:31 AM
fomocojoe101 fomocojoe101 is offline
fomocojoe101 is starting off with a positive reputation.
backup lights
Scratching my head, trying to remember, (got C R S) but I believe there is a reverse light switch on the transmission, or possibly on the steering colume. Try looking at the trans first!
Old 10-27-2004, 01:17 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The problem is the combination back-up light/neutral safety switch.
Remove the switch from the side of the transmission & unplug the connector on the firewall.
Submerge the switch part in some Lacquer Thinner & shake,turn the inner collar of the switch ...repeat until the switch seems clean...Then clean again with electrical cleaner moving the switch inner colllar as you spray fluid inside.
Now you can re-attach the connector & tes the switch before mounting it back on the tranny.
If it now works get a drill bit that will fit in the hole & and install on transmission as per specs.
95 f250 reverse gear problems Sam's The Man 1987 - 1996 F150 & Larger F-Series Trucks 5 03-06-2016 08:28 AM
Reverse lights quit working exbxtoy Excursion - King of SUVs 1 01-30-2015 10:53 AM
No tail lights but every thing else works countryboy5487 1987 - 1996 F150 & Larger F-Series Trucks 5 12-04-2014 05:27 AM
E250 reverse lights AdventElect 1968-2013 Full Size Vans 5 05-25-2011 04:43 PM
Reverse lights no worky Wakeboarder141 1978 - 1996 Big Bronco 4 03-16-2003 12:31 AM
Tags
04, 1979, 2004, 96, 99, back, backup, dont, explorer, f150, ford, lights, reverse, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
