Wipers won't park/ no intermittent
My 86 Bronco has an intermittent problem with the wipers that's becomming more frequent. The intermittent wiper feature doesn't work - turning to the intermittent function only gives the same low speed with no delay. Low speed and high speed work ok, but the wipers will not park by themselves. I'd guess it's the delay module, but the parking function is usually part of the wiper motor. Can anyone tell me which part is the problem?
However, the "park" function relys on positioning of the motor gearing. The motor has a set of contacts in the gearhead that keep the wipers running until they are in the "full down" position. If the contacts in the gearhead are corroded or broken they will not park. And every time the intermittant relay triggers it starts the wiper motor but relys on the "park" contacts to stop the motor in the right position. The intermittant function is a recylcling time delay relay that changes time based on changes in input voltage from the delay dial and resistors.
Billybob,
I try... most people's patience, but I try. The delay module you referred to is the recycling time delay relay I was talking about and the input voltage change is affected by moving the dial on the intermittant setting for the wipers. The dial changes the resistance value feeding the delay module and thats what makes the relay cycle at slower or faster intervals. Hopes thats a little less murky.
Awwww, Crapola!!
Well. I had a heck of a time replacing the wiper motor - I bent two windshield moldings and the cowl panel. I did it at night, and I was determined to ""git er done" as they say. I won't do that again.
As if it weren't bad enough, it wasn't the wiper motor - though it sure acted like the parking contacts were worn out. I unplugged & reconnected the connector at the wiper switch, and it worked again. There's $40.00 (plus cost of replacing moldings) that could have gone toward a new paint job.
It was a good guess, but still just a guess. In any case, it's a lot less than a car payment.
phoneman91
62
03-13-2024 09:16 PM
four-sixty-power
02-24-2017 10:15 AM
granny_rocket
10-13-2013 05:48 PM
