Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 10-27-2004, 08:11 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
That annoying door chime is finally quiet!
Well folks this was a real easy one. After reading some of the posts here on FTE about how to shut up the door chime with the key in, I took the plunge. I started by removing the three screws that hold bottom half of the steering column cover. The cover basically falls off, revealing the black with pink stripe wire going up to the ignition lock tumbler. You can't miss it, it's the only one going to the base of the tumbler. Turn the key to the "on" position and push the retainer button on the bottom of the tumbler housing and remove the key tumbler. The button is located about a key lengths distance from the hilt of the key as it's inserted in the lock. It looks like a small ball bearing in a hole. Just get a small screwdriver and push on the ball bearing and pull on the lock tumbler at the same time. Out she comes. Ok now remove the top half of the steering column cover. Examining the black/ping wire you will see that it comes up to a small horseshoe plastic retainer that fits onto the bottom of the lock tumbler housing like a set of dentures. Simply slide it out of it's groove and wrap it up with a bit of electrical tape and stash it under the tumbler housing. That part is done. Now you know that very annoying lever that you must push on to get the lock tumbler to turn all the way to the off position and remove the key? It's held down with one bolt. With the cover off of the steering column it's a 30 second affair to remove that annoying little lever that was put there by Ford's liability lawyers. It's a Torx fitting. I didn't bother with going to the tool box and getting one, I just used the pliers that were handy sitting on the floor while I was working and it came out easily. Put the top cover back on the steering column now. Insert the lock tumbler now. Turn the key off. Install the bottom cover. Now you can insert the key in the ignition with the driver's door opened and the chime will not sound. You turn the headlights on it it WILL sound. Key in or not.
One last thing. Go under the driver's seat and unplug the electrical plug under there to shut up the seat belt chime. Now the next time you get in the truck and turn the key on you will only hear the chime tone one beep and that's it with the door open and the seat belt unbuckled. Just please keep wearing your seat belt. I heard a fireman say a long time ago and it stuck in my mind. "I have never had to unbuckle a dead person."
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #2 (permalink)
Old 10-27-2004, 08:19 AM
HeatStroked's Avatar
HeatStroked HeatStroked is offline
Garage is empty, add now
HeatStroked is gaining momentum as a positive member of FTE.HeatStroked is gaining momentum as a positive member of FTE.
Great information Kwik!
As an option to the seat belt chime: There is a procedure in my "02" owners manual that disables the seat belt chime by turning your headlights and ignition on and off in a certain timed sequence. Follow the instructions exactly or the disable wont work.
  #3 (permalink)
Old 10-27-2004, 08:33 AM
1999 Ford F-550
I read that post and tried to find it in my '99 owner's manual with no luck. I had no choice but to unplug the harness under the seat. Same effect, different solution.
__________________
Dan
  #4 (permalink)
Old 10-27-2004, 08:39 AM
Yeah, not sure if it works on earlier PSD's. If I couldn't get that sequence to work, the disconnect was going to be my back up.
  #5 (permalink)
Old 10-27-2004, 03:28 PM
Jerrybo66's Avatar
Jerrybo66 Jerrybo66 is offline
Jerrybo66 is starting off with a positive reputation.
Kwikkordead.
I used to consider myself a half decent back ally mechanic but now, nearly everything I get into turns into a can of worms. Your highly detailed directions on how to disarm the obnoxious chime may be a "real easy one " for you but it probably would be the famous "can of worms for" me. So, I ask you, if the black wire with the pink stripe is the only one to go to the ignition lock tumbler, would cutting that wire accomplish the same as removing the little switch in the tumbler. I think I could handle the three screws and do the snip without getting into too much trouble. .. Waddayathink ??
Thanks..
(PS. I can't believe I changed the tranny fluid yesterday...Here's hoping... I haven't taken it for a test run yet...)
__________________
1997 350, PSD, 4X4, Red, Crew cab, long bed, high-cap.
1973 F100, 360, 4 spd. manual
  #6 (permalink)
Old 10-27-2004, 04:20 PM
FoMoCo136's Avatar
FoMoCo136 FoMoCo136 is offline
FoMoCo136 is starting off with a positive reputation.
Jerry, I would think so but why cut your harness? Only one more steep and you got it.
__________________
2006 F-150 4X4 3" Leveling Kit Nitto 35", SCT Tuner, All the gauges, Heavy Right Foot
  #7 (permalink)
Old 10-27-2004, 04:56 PM
refuse2 refuse2 is offline
refuse2 is starting off with a positive reputation.
I pulled my ignition switch out and put a strip of black tape over one of the metal strips and no more door chime with the key in and I love it. Very easy to do and I didn't even have to pull any of the covers off of the column at all it was that simple.
refuse2
__________________
2005 F-250 Dark Toreador Red, Lariat Lux. package, 6.0 PSD, Torqueshift auto trans, 4x4, ESOF, tow command, Sirius Satellite radio, Retrax bed cover, MagnaFlow 4" turbo back minus kitty, CCV mod, Oil Guard by-pass, and Schaeffers 5w40.
  #8 (permalink)
Old 10-27-2004, 05:10 PM
RedStroker6's Avatar
RedStroker6 RedStroker6 is offline
RedStroker6 is starting off with a positive reputation.
looks liek that lever is gonna be gone soon.....but where can i get a new ignition/tumbler....all that good stuff. my key is really loose in the ig. and i had read that its easy to change...with another tumbler that is...where cani get it?
__________________
Adam
95 f250 PSD ZF5. Twin 5" stacks, 5.6K, 6637, Kenwood Deck, 2 Kicker CVR 10's, Audiobahn amp, AutoMeter Pyro. ugly truck but my gal loves it
  #9 (permalink)
Old 10-27-2004, 07:23 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud ofcookie88 has much to be proud of
f250juggernaut
It does not work on the earlier ones (2001's included ) however, we can simply push the release button on the seat belt latch and it shuts it off for that drive cycle......or unplug it.
__________________
Scott - FTE moderator
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
  #10 (permalink)
Old 10-27-2004, 11:29 PM
1999 Ford F-550
Quote:
Originally Posted by Jerrybo66
Kwikkordead.
Thanks..
I see by your profile that you have the earlier style pickup. Your's has the remote chimer box that is mounted up to the right side of the accelorator pedal. Just open the door, turn the headlights on and follow the noise to the little 2 inch square box with the umbilical cord plugged into it. Unplug the cord from the box and you're done.
__________________
Dan
  #11 (permalink)
Old 10-28-2004, 07:19 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant future
Roland Mueck
RedStroker6,
You can get a new ignition lock cylinder and key set at your local auto parts store. It is very easy to replace by pushing in the small pin facing down on the end of the lock cylinder while the key is in the "on" position. Simply install in reverse order and the pin will extend to lock into place when the key is turned to "off". Some vehicle models have a small hole in the cover to access this pin with a small punch or pick without removing the cover. LOL
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Fuel Bowl delete, 910 Springs, mueckster built 4R100, 4" SS MBRP, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
  #12 (permalink)
Old 10-28-2004, 07:26 AM
fordnut74 fordnut74 is offline
fordnut74 is starting off with a positive reputation.
Kudos KWIK, I have been thinking about trying to shut that stinkin thing for a while. Hopefully this weekend the sounds of silence will reign, thanks
__________________
99 SD PSD, CC, SB, 4X4, Phantom gages, bypassed wastegate, a/p regulator to avoid defuleing, Home made SVO kit, Edge Evolution, 6637 air filter, straight piped exh, 15.2@86 1/4 mile
  #13 (permalink)
Old 10-28-2004, 09:28 AM
1999 Ford F-550
The whole job took less than an hour, including pausing and looking around at things I had not seen before to familiarize myself with the design.
__________________
Dan
  #14 (permalink)
Old 10-29-2004, 12:02 AM
Jerrybo66's Avatar
Kwickk
Sounds good...................Thanks.......
__________________
  #15 (permalink)
Old 10-29-2004, 12:55 AM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
I unplugged the harness for the seat belts and also for the door chimes (under the dash). I figure this way when I sell the truck some day I can reattach it.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
Tags
1999, 2003, chime, delete, disarm, door, explorer, f250, ford, key, location, ranger, seatbelt, stuck, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
