That annoying door chime is finally quiet!
#65
Here is how I did mine on my 01. Yes it is the black with pink wire. If you pull the fuse cover off off under the column. You know the big panel at your legs with the four plastic screws. You can reach to the right side and grab the harness. There is a plug assembly right there. I unpluged that assembly and pulled the red clip out that hold the pins tight. Use a small pick and pop that one terminal.wrap it with tape or a piece of heat shrink tubing. leave it out. put the red clip back in and snap the harness back together. It took less than ten minutes and nothing is cut. The seat belt chime still works but it kills they key chime.
#66
#68
Originally Posted by mueckster
Has anyone noticed that after you dosconnected the black with pink wire that the chime still works with the door open and the key in accesssory? I haven't got to figure this one out yet. I need a wiring diagram for the chime circuit.
#70
I'm gonna check my owners manual for the 2 page & 47 dance step fix before cutting the wire. (2001 F-250 psd cc 4x4). but I had an idea for the guy with the key and tumbler issue. If you go to the ford dealer with your vin they can cut you a new key.and give you the code that goes with a replacement motorcraft key and tumbler. you change the tumblers to the code and your key cut stays the same. so your doors and ignition are'nt different as with an aftermarket key and tumbler.
#71
on
cangim,
The tone,with door open/ key in accessory, is a continual on-off chime. It continues until I close the door or take the ignition out of accessory. The chime is off when in the ignition position, with or without the door open. Tried removing the interior light fuses to see if power, when the door was opened, was triggering the chime. Lights went out, but chime stayed on. I would like to find the "trigger" wire, so I can disconnect it. I do not have any wiring schematics for the GEM. It looks like the chime is part of this module.
#72
hey, is there any way to disable the door chime when the key is in the acc position? We like to play the stereo quite loud with the doors open, and I notice even with the black/pink wire modification, the door still chimes with the key in acc. position. I don't really want to hot wire my stereo direct to the battery... help??
#73
Well all I did was disconnect the wire out of the tumbler so it wouldn't register the key. When I turn to the accessory postion I get a long tone of about 2 sec. then all turns off. No beeping tones. Mueckster, I dont understand yours, unless there is more than one wire that is black w/pink stripe. Yours sounds to be operating as normal rather than disabled at all. I'd pull the casings off and take it out of the tumbler and see if that is what fixes the problem.
#74
on
#75
hmmmmm interesting. Seems to me it's something still within the ignition switch circuit (althought my connector has been removed), as it doesn't chime with the key in "off" position, but as soon as current is applied thru the "Acc" position, the chime goes off again. The must be a second wire causing this. My Haynes manual has different wiring for the 99-01 trucks, and then 2002 is totally different from those from what I see.
