351w oil pressure sensor - Ford Truck Enthusiasts Forums
Old 10-26-2004, 06:48 PM
kenmaraz kenmaraz is offline
kenmaraz is starting off with a positive reputation.
Hello again. I've got a 351w, that didn't have an oil pressure sensor installed, so I bought one to go with the new vdo gauges. It's the 'canister' looking type. I installed it, wired it, but do not get an oil pressure reading. And as a rookie mistake, I took it out then cranked the engine to make sure I had pressure.....well guessing by the oil that squirted out across my garage, I think that's fine. Are there different types of sensors? I told the guy at Checker it was for a 351w with a pressure guage when I bought it. Any ideas?
Old 10-26-2004, 07:40 PM
Technonut Technonut is offline
Technonut is starting off with a positive reputation.
Did the sending unit come with the VDO gauge? If not, I would imagine that you will have to purchase the matching VDO sending unit for that particular gauge....
Old 10-26-2004, 09:01 PM
hdgapeach hdgapeach is offline
hdgapeach is starting off with a positive reputation.
If it is a one wire sender, it grounds to the block with the threads that screws into the block. I've seen senders that didn't work because they couldn't ground through teflon tape wrapped around the threads to prevent possible oil leaks. If you used any thread sealer, this may be your problem.
Old 10-30-2004, 12:10 PM
Well, I broke down and bought the vdo sending unit, and now it works. Lesson learned, can't mix vdo gauge, with a non vdo sender. Thanks everyone
Oil pressure sender leaking Radi 6.0L Power Stroke Diesel 16 01-20-2015 07:44 PM
Oil pressure switch socket / size Onus 1987 - 1996 F150 & Larger F-Series Trucks 11 12-14-2010 02:24 PM
91 351w oil pressure crewcab77 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 02-16-2005 12:45 AM
what should my oil pressure be? 351W koalamazed Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 03-08-2004 09:21 AM
low oil pressure on a fresh rebuild 351W myeverett Performance & General Engine Building 7 11-19-2002 07:11 PM
Tags
351, 351w, change, ford, location, locations, oil, pressure, replacement, sender, sending, sensor, switch, unit, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
