how can i measure engine rpm...... - Ford Truck Enthusiasts Forums
Old 10-26-2004, 02:49 PM
maxidog-ranger maxidog-ranger is offline
maxidog-ranger is starting off with a positive reputation.
Cool how can i measure engine rpm......
how can i measure the engine rpm in my 92 2.3 without having a tach?
Old 10-26-2004, 09:58 PM
seth1's Avatar
seth1 seth1 is offline
seth1 is starting off with a positive reputation.
there is a electric meter u can get and tap into a wire on the DIS. i am not sure what wire i can check if u want. the meter is a special one though. probly expensive. just go to a junk yard and pick up the whole guage cluster and swap your old one out. the plugs were the same and the wires were all run, so just plug it in. this is what i did. i would make sure your get the 92 guages just to make sure.
How to Set 352 Timing w/Vac Advance 64F-100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 09-29-2016 09:04 AM
Lining up a new core support? ghunt Paint & Bodywork 7 05-26-2015 10:58 AM
Is the frame bent or different size fenders? 49f3dls 1948 - 1956 F1, F100 & Larger F-Series Trucks 49 09-19-2013 01:47 PM
FE Engines - 410 Mercury vs. 390 Ford Mercmeister 1961 - 1966 F-100 & Larger F-Series Trucks 4 10-05-2010 10:32 PM
RPM, Tires Sizes, Rim Sizes RPM Calculator four8fordf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 11-11-2008 05:20 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
289, auto, diesel, engine, engines, ford, gas, gauge, measure, measurement, measuring, rpm, rpms, speed, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
