1993 ranger help! - Ford Truck Enthusiasts Forums
1993 ranger help!
Old 10-26-2004, 01:27 PM
fried_guy fried_guy is offline
fried_guy is starting off with a positive reputation.
1993 ranger help!
My friend has a 1993 2.3L ranger that just blew a head gasket. He is about to get a new truck, but before he does he wants to see what we can do to it.
Currently we have the head off and everything looks good. The cross-hatch is still on the cylinder bores after 100K+ miles, there seems to be little wear on the cylinder walls, etc.
I will be doing a home p/p job on the head and the intake, adding larger intake valves with a 3-angle valve job, shaving the head some to gain compression, using a thinner head gasket to raise compression and to get a better quench area, and adding a new aftermarket camshaft.
I really don't care what he HP/TQ was on that model, but I need to know the compression ratio, the gasket thickness, the piston valve relief cc, the piston compression height, and the head cc.
Can someone please tell me the compression ratio of the 93 ranger 2.3?
Also, I measured the thickness of the head gasket and got .046"... is this correct?
I also cc'd the pistons and found the valve reliefs to be .5cc... is this correct?
I've searched for piston comression height and get conflicting answers... can someone please tell me the stock compression height of these pistons as well?
I haven't cc'd the head yet because the old camshaft is still in there... can someone please tell me the head cc too?
I know I'm asking a lot and I appreciate your help.
TIA,
Casey
Old 10-29-2004, 06:54 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
I'm not an expert at all, but the head gasket & valve relief #s sound the same as most other engines.
Have you looked in a performance shop to see if there's a HP book on the 2.3?
AL.
Do 429 Cobrajet pistons have higher compression height than 429 thunderjet (std) 1972 Ford Thunderbird 429 V8 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 12-19-2008 05:42 PM
Which pistons for my 466 build? booneyrat75 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 11-04-2005 07:04 PM
piston dish volume, anyone?? werkdatool 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 03-17-2004 03:12 AM
Valve relief cc, deck height SpeedPro/TRW L2291F30 DuckRyder FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 09-08-2003 04:55 AM
compression 400 sampsin 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 01-09-2003 06:04 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, 93, casey, compression, friedguy, ranger, ratio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
