1989 Ford Bronco II
1989 Ford Bronco II
Hi,
My antifreeze keeps disappearing. It is not being sprayed anywhere that I can see. I have had my heating core changed, my head gaskets were changed as well....there did not seem to be a crack anywhere. None seems to be going in my oil. I have had a new transmission, gas tank and fuel pump. I need to find what is causing this as it cost me each time I have a mechanic look at it. The owners manual does not tell me.
Thank-you
Laura
Thank-you
Laura
Originally Posted by Laura Smith
Hi,
Thank-you
Laura
Thank-you
Laura
Approximately how much is being lost? Have you had the radiator drained lately? If so, it could be that the system wasn't completely filled. If this is the case, you can fill it to where it looks full, but when you check later, it will be low. Make sure it's full (in other words, make sure there is no air in the system). Another idea. Although you said you can't see where it's spraying from, have you taken a look at the freeze plugs? Even if one (or more) is leaking, it won't necessarily spray it all over the place. Those are all my ideas for now. Of course, those are ruling out the idea that it is indeed not leaking internally.
I had a coolant leak just after replacing head gaskets (a different vehicle, but that's irrelevant to this story). I couldn't figure out where the heck the coolant was going. My first thought was that I had a head gasket leak since that was what I'd just worked on. However, as best I could tell, there was no coolant in the oil and no coolant in the exhaust. Yet every time after I'd taken it for a drive the coolant would be low. To cut a story short, it turned out that there was a puncture in the pipe that ran from the radiator to the overflow reservoir. When the coolant heated up it expanded and pushed some out of the radiator whence it either spilled on the ground and/or was burnt off the engine, or sent to the overflow reservoir. Most of it evidently went on the ground. When the engine cooled down the radiator would suck in air, rather than coolant, and after it had cooled enough that I could open it the level would be low again.
If coolant is disappearing it is going somewhere. This is one possible explanation for a mysterious coolant leak.
1989 Bronco II rad leak
Originally Posted by BigBill
Im just curious but where do you notice that it is draining from. Like the overflow or from the radiator?
Hi Plilikoi, Thank-you for your reply...not one mechanic has mentioned about the pipe maybe having a leak. I had checked the pipes myself, but not being able to put vehicle on a lift, I could not see anything leaking. Even tho I put coolant in the over flow it as well disappears. You may have solved my problem. I will have all the hose and pipes checked today. Thank-you so much. I am endebited to u if that is the prob as I paid 1800. two years ago and have put 5000. in since. You know dumb blond and mechanic. Have a go day. Laura
You don't need to put the vehicle on a lift since the hose runs from the radiator cap to the overflow reservoir. It could probably bear replacing even if it looks good. Shouldn't cost more than a couple of bucks.
Good luck to you.
1989 Ford Bronco II
Originally Posted by Avanti
Check the water pump weep hole. Put a small piece of kleenix in the hole , run the engine and check it later after cooling down to see if it is wet or none white. Some times it is the weep hole. john
lauraj
01-06-2014 02:02 AM
