wiring a 3rd brake light in topper
Old 10-26-2004, 11:35 AM
super440's Avatar
super440
super440 is offline
just wondering where to get the feed for a 3rd brake light in a topper. I know the older trucks had a wire in the taillight harness, but i dont see it on the 04.
Old 10-26-2004, 02:10 PM
High Cotton's Avatar
High Cotton
High Cotton is offline
I had mine installed nearly a year ago and they had to go up to the left front of the truck (drivers side) and look for a green wire on the frame rail. The other 2 wires were at the taillight. Good luck.........
Old 10-26-2004, 04:01 PM
dkshado's Avatar
dkshado
dkshado is offline
The cap installer tapped my third brake light wire in the door channel on the right side of the truck.
Old 10-26-2004, 04:10 PM
super440's Avatar
super440
super440 is offline
Thumbs up
Thanks guys, I'll be able to find it now, wouldnt have thought it would be so far up the harness.
Old 10-27-2004, 02:07 AM
Vinheyhey's Avatar
Vinheyhey
Vinheyhey is offline
Wire
Hi Supper440,
If you have a hitch,you can tap thru it, for i put a bully third brake lite on mine with the ford logo and just pluged it in . Just make sure you install the towing fuse that came in the glove box when new . hope it helps .
Vinnie M.
Old 10-27-2004, 10:23 PM
blub's Avatar
blub
blub is offline
Same color as the little dot by my name.
I had my Leer top put on Sunday and watched the guy do it. It's the green wire under drivers side channel under the door. Make sure it's the garden hose green colored one. Same color as the little colored dot by my name on this post, up there where it says Blub
Old 10-30-2004, 09:46 PM
seppypom's Avatar
seppypom
seppypom is offline
Originally Posted by Vinheyhey
Hi Supper440,
Vinnie M.
It is a relay, not a fuse!
Bob R..
2017+ Super Duty
01-03-2017 12:41 PM
stufarmer
1999 to 2016 Super Duty
05-20-2016 04:08 PM
Blujay96
06-11-2010 11:33 AM
vtx1800
2004 - 2008 F150
02-28-2010 10:54 AM
schpifford
Electrical Systems/Wiring
11-03-2008 11:09 AM
Quick Reply: wiring a 3rd brake light in topper
