Idle Question - Ford Truck Enthusiasts Forums
Idle Question
Old 10-25-2004, 08:45 PM
rrsandifer rrsandifer is offline
rrsandifer is starting off with a positive reputation.
Idle Question
Hey guys was just wondering if anyone has ever had this problem. I have a 97 ranger 2.3L std trans and just finished replacing plugs and wires. It runs good but Ive noticed now that when you rev the engine up and let off the gas the engine idles down real low almost dieing then goes back up to around 700 rpm about where it should be. I do not recall it doing this before.
Old 10-29-2004, 06:48 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
Disconnect the battery for 20 minutes. Re-connect & start the truck & ONLY let it idle, don't touch the gas, for 5 minutes. This way it will re-learn the idle.
Open up the air intake tube & inspect the throttle plate & bore for "dirt", gum, carbon build-up. Clean it up with aerosol carb cleaner.
AL.
Old 10-29-2004, 09:20 PM
Thanks DealFord I will give it a try. This tthing has been driving me nuts. Have a good one and thanks again for the reply.
Old 12-10-2004, 07:56 PM
Hardwareman Hardwareman is offline
Hardwareman is starting off with a positive reputation.
If that does'nt fix it, go buy an I.A.C. (idle air control valve) at Auto Zone.Will clear it right up!
Go Back   Ford Truck Enthusiasts Forums > >
Tags
gas, idles, low, real, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
