You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Got my results back on my oil samples, One was taken from my first oil change which was run on only diesel, and one was from my most recent oil change, run mostly on Veg oil. A few items went up a small amount, most notably the sodium. Not sure what that indicates, or what problems it will cause, if any. These small changes may be due to the Veg Oil, or the added stress of the MODS I have done. Either way, They say there is nothing to worry about. Also noted was that my oil was still in good shape at 5,600 miles, so I may bump my interval up to 7, 500 for this cycle and retest.
Here are the links to the Normal and Veg Oil samples
__________________
99 SD PSD, CC, SB, 4X4, Phantom gages, bypassed wastegate, a/p regulator to avoid defuleing, Home made SVO kit, Edge Evolution, 6637 air filter, straight piped exh, 15.2@86 1/4 mile
Fordnut, did you have to refine the oil somehow before you used it? i had heared of vegie oil used w/diesel, but not as a motor oil replacement. is there a thread somewhere i can find out more? sounds spiffy...
__________________ Adam
95 f250 PSD ZF5. Twin 5" stacks, 5.6K, 6637, Kenwood Deck, 2 Kicker CVR 10's, Audiobahn amp, AutoMeter Pyro. ugly truck but my gal loves it
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
Hey Fordnut you need to relax restrictions on your MSN groups there. It's asking for a .NET username and password.
__________________
Dan
I am not sure why it was restricted, never used to be, but It shouldn't be anymore.
Leave it to Microsoft to screw things up. As of tuesday morning, it's still requiring a .NET username and password.
__________________
Dan
you know, sometimes I really don't like Microsoft. trying it out from my work computer I am having the same problems. So I did some typing, conversions, cut and past and posted a barely legible copy on my galleries, hopefully HERE The left column is the veg oil, middle column is my trucks average, and the right is the diesel only
__________________
That time I was able to see it. Iron's kind of high with the veggie. You might want to stick with diesel until the engine is FULLY warmed up so that glycerin will burn better. I wouldn't be surprised if that's the cylinder walls going due to washdown.
__________________
Dan
what kind of milage do you get per gallon of diesel when you run the veggie oil? or is it the same, just less diesel use per mile? er....something like that
ok...after doing some more informed reading on some of Fordnuts other posts, i understand better now. who woulda thought the engine could run on straight veggie oil? makes me wanna try it out now....is there a website somewhere that will tell me more? besides biodiesel...that stuff doesn't sound too super yet because of the prices.
__________________
Dan
Wow, I really need to crawl out from under my rock more often, Only after ken notified me that he moved my thread, did I realize there was an alternative fuels section added But in that respect cool!!
Redstroke- there are several sites that have various info on this topic, the three I frequent the most are greasel.com, alternative fuels at The Diesel Stop, and http://www.vegburner.co.uk/index.html. It is kind of hard to keep track, but on a recent 2,500 mile road trip to Vegas and back I figure I averaged 15mpg, running only SVO.
Kwik- I called Blackstone to voice my(your) concern on the high iron. They said that at this point it is nothing to worry about, and the increased levels are moe than liekly due to the fact that I have increased the power of the motor almost 50% since the first sample was done. I am going to do another oil change at the same 5,600 mile interval with no other changes to the motor to establish a baseline for my motor from which to referance future analysis. Each motor has its own distinct wear patern, and can change a small amount based on type of oil, change interval, operational usage, and MODIFICATIONs . The lady I talked with was the one who did my analysis, and said that there isn't anything I should be concerned at this point.
__________________
