Overdrive Surge of Missing Engine?
I have noticed latley when my '01 F150 5.4L shifts from overdrive to a lower gear, there is a surge. I think it feels like the transmission slipping, a local shop told me that I may need new wires and plugs because they think it is the engine missing. If I turn the overdrive off, this does not happen, but the engine stays at a higher RPM the whole time. Is any one else seen this before?
hey i had the same problem, i had bosch platinum plugs. i sware i thought it was my tranny, it would feel like it was sliipin like a bitch. but i got ngk iridium plugs, 9 bucks a piece. now its runnin great. i would try that before goin all out and throwning down a n 800 or 1200 on a tranny. hit me up man, laters
Hi Brad and welcome
Like dorianrey said it could easily be a spark plug problem. Hopefully the shop that told you it needed wires didn't actually look at the truck....it has no plug wires. It uses COPs (Coil On Plug) instead.
If it feels more like a shudder when it shifts the problem could be as simple as the transmission oil needing changing. After a while the oil can break down and cause the torque convertor to shudder as it locks and unlocks.
I did have the Trans Oil completly flushed and replaced thinking that this would help, but 300 miles later it is still doing it. I did ask the shop about the "wires" when they told me that because I knew that they this engine didn't use wires but the spring and boot setup instead, and they said they just say wires because most people don't know what the other is.
So, I think I will try new plugs now and see what happens.
Thanks, I will let you know in a few days.
Bad COP
I had the exact same problem at 48,000 miles and started out at a transmission shop. They (honestly) said the trans was ok and suggested I had a misfire problem. Three trips to the engine mechanic and he found a bad COP (coil). He also said the 100,000 mile plugs looked pretty bad. Replaced them with OEM too. No misfire codes were ever recorded. Truck runs great now.
ok ok i put in the 9 dollar iridium plugs thinking it was gonna run like a champ, then it crapped on me in three days, so i go back and buy the champion copper ones, a dollar a pice the truck runs like a freakn animal now, cant believe it, but its true, if you have force induction dont go with iridium, learn from me ,my mistake, cost me like 80 bucks,lol
rva33145
08-27-2006 03:39 PM
