1999 Ranger clutch problem - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-05-2002, 03:57 PM
kmmcneal kmmcneal is offline
kmmcneal is starting off with a positive reputation.
I own a 1999 Ranger, 4.0 V6 with a manual transmission. I live in an area where the temperature is not uncommon to be over 100 degrees from June through August. During these 100+ days, I have noticed that the feel of my clutch drastically changes. What happens is that the clutch doesn't want to completely disengage when I have the pedal all the way to the floor. Sometimes so bad that to get it into gear is very difficult. When I release the pedal it seems to catch very quickly and the pedal has barely been lifted off the floor.
Can anyone help me understand why the feel of my clutch would change when the temperature increases and if there is anything I can do to fix it. During the winter I never have this problem, the clutch acts normal. I noticed the problem first during last summer and now again this summer.
Please help!
Old 06-11-2002, 12:48 AM
bubbernator bubbernator is offline
bubbernator is starting off with a positive reputation.
It sounds like an air bubble in a hydraulic line, but that wouldn't be temperature sensitive. Are you in the desert S.W., and if so, has alot of dust gotten onto or into your clutch master cylinder? Desert dust eats wheel bearings for breakfast and hydraulic systems for lunch. The O-rings on the master cylinder or concentric clutch release (slave) cylinder may be borderline. How many miles? Any off-road?
CB
Old 06-11-2002, 09:52 AM
I live in central California and I do quite a bit of offroad driving (i.e. fire roads, access to dirtbiking areas). I know that a lot of dust gets into my truck. I currently have about 46k miles and it could very well be that my master cylinder has a lot of dust eating at the seals. I will have to check it out.
Thanks for the advice, if there are any other thoughts I am open to ideas.
Old 07-24-2002, 06:19 PM
neufelda neufelda is offline
neufelda is starting off with a positive reputation.
Post 1999 Ranger clutch problem
I have a '99 with a 4 banger, 2WD, that is similar. The clutch pedal free-play can vary from 1/2 inch in cold weather to 1.5 inch in hot weather after a long drive. So far there is no problem shifting and the dealer can find nothing wrong.
Have you gotten anywhere with this?
Old 07-30-2002, 01:42 PM
fordtruckssuck fordtruckssuck is offline
fordtruckssuck is starting off with a positive reputation.
I just spoke with my Ford mechanic and have the same problem on my 2002 4.0L 5spd. FX4. He said its the slave cylinder allowing air into the system. Pull the tranny and replace. He also said that Ford has 5 revisions out for this slave cylinder and they still can't get it right! Come on Ford, get new engineers if you can't figure it out.
Old 07-30-2002, 11:45 PM
dzk007 dzk007 is offline
dzk007 is starting off with a positive reputation.
Try using sythetic fluid. Very pricey but it retains its properties at higher temperatures.
Old 07-31-2002, 05:11 PM
Does Ford have a service bulletin out on this? Anyone know the number?
I brought my 4 cyl. truck in for it last year while still under warranty and they didn't find a problem, or service bulletin
Old 10-21-2002, 01:13 PM
I just had another thought on this. My clutch lines are plastic and it wouldn't surprise me if they soften when it gets hot. A little bit of softening would go a long way to explaining this problem.
Are your's also plastic?
Old 10-21-2002, 02:45 PM
TRX250R87 TRX250R87 is offline
TRX250R87 is starting off with a positive reputation.
I have a 99 Mazda B4000 5 speed with a little over 46K miles and I have had the same probles for over a year! It seems like the free play in my clutch petal changes all the time. Sometimes I have to put it almost to the floor, sometimes it is stiff right away. I had something replaced under warranty that was master or slave cylinder related, I would have to check the paperwork to know exactly. The problem was fixed, for a while. I brought it in again and the dealer said "trucks just shift harder than cars" and didn't fix it!
ERIC
Old 10-21-2002, 04:39 PM
Eric,
Did the freeplay increase as the weather got hotter? What part of the country are you in?
Old 10-22-2002, 09:21 AM
I'm in Wisconsin and see all types of weather. I notice that in winter the shifting seems more difficult but gets better when everything warmms up.
ERIC
Old 10-22-2002, 12:14 PM
It sounds like we have entirely different problems. My shifting is fine, only my clutch freeplay is a concern.
You may try using a synthetic gear lube, if you haven't already.
Art
Old 10-22-2002, 12:36 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Clutch pedal Bste4805 Clutch, Transmission, Differential, Axle & Transfer Case 2 01-12-2014 03:23 PM
Clutch rod to clutch pedal plastic retainer Eaglefixer Ranger & B-Series 2 11-30-2009 01:24 PM
Need help with clutch adjustment on 88 F150 GUERILLA 1987 - 1996 F150 & Larger F-Series Trucks 4 05-08-2009 10:20 AM
Very hard clutch pedal, won't disengage mfoxcontract Ranger & B-Series 4 03-13-2007 11:07 PM
Clutch pedal loopy! Polkat Clutch, Transmission, Differential, Axle & Transfer Case 10 11-02-2002 09:50 PM
Tags
clutch, cylinder, fan, ford, hot, master, problem, ranger, sensitive, temperature, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
