Excessive Oil Consumption, No Smoke! - Page 4 - Ford Truck Enthusiasts Forums
Closed Thread
  #46
Old 07-25-2014, 10:08 AM
landtortise89 landtortise89 is offline
landtortise89 is starting off with a positive reputation.
it has a napa gold filter on it which is a wix (good paper filter) I tend to like to run motorcraft filters on my fords. running a synthetic oil in my truck is going to do nothing but increase my oil consumption i will not do it until the consumption issue is stopped it's expensive enough trying to feed it conventional oil at $3.50 a qt let alone a good synthetic at over $9 a qt.
  #47
Old 07-25-2014, 10:18 AM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
If your going through it that fast, I would just buy some Accel brand motor oil. Its still manufactured by WPP and they do a good job at producing the Supertech oil offered at Walmart. The Accel is listed at $2.67 a qt. That's 10w-30, 10w-40. If the consumption slows dramatically, then switch to any brand you prefer, but till then I would stick with a cheaper brand.
  #48
Old 07-25-2014, 10:26 AM
yeah I have been buy catrol gtx from napa cuz it's $3.49 a qt right now but always looking for cheaper options. I am hoping to get my wifes windstar running right so I can garage the truck and pull the valve covers off of it. I figure i'll just do the valve seals and hope it slows down. I pulled the PCV off last night and changed it to the motorcraft one, my cheap one was clean inside which i found interesting due to the oil consupmtion.
  #49
Old 07-25-2014, 10:45 AM
jasoncarpenter1's Avatar
jasoncarpenter1 jasoncarpenter1 is offline
jasoncarpenter1 is gaining momentum as a positive member of FTE.
I thought I was the only one with a oil drinking 460...........
I go through two quarts every few hundred miles.........I use the cheap wal-mart oil. Keep a 5 quart jug in the back........
  #50
Old 07-25-2014, 10:47 AM
yeah mine seems to use a qt every 30-40 miles lol it sucks.
  #51
Old 07-25-2014, 11:21 AM
Holmesuser01 Holmesuser01 is offline
Holmesuser01 is starting off with a positive reputation.
I've got a '94 with the 300 six. When I got it, the engine was covered with oil, and it dripped allover everything.
I pulled the PCV valve, and had no vacuum. The hose between the manifold and the valve was clogged solid.
I soaked the valve in some gasoline (I know, explosive... no smoking around this) and squirted PB blaster into the hose after I removed it from the truck, and then snaked a wire through the hose. I eventually got it cleaned out, and the gas dissolved the build-up in the valve.
Now, there is nothing leaking anywhere. I have not replaced any gaskets, yet, and the oil usage has gone to almost nothing.
Good luck with your 460. You'll find the problem.
  #52
Old 07-25-2014, 07:06 PM
idiabuse idiabuse is offline
idiabuse is gaining momentum as a positive member of FTE.
Quote:
LOL! afraid to learn new tricks!
I used to think that way, I got tired of being stuck on the corner!
  #53
Old 07-25-2014, 07:07 PM
Now you know why you have the results you have, when you cut open your hand, will it heal in the same day?
  #54
Old 07-25-2014, 07:09 PM
I pay $10 a quart at the minimum, I don't have any of these problems posted on this thread, I solve these problems for people instead.
  #55
Old 07-25-2014, 08:57 PM
Do you have anything of positive info that can relate to something OTHER than AMSOIL??
If it was directly related to NOT using AMSOIL, then prove the members of FTE otherwise. Some of the folks here have 300's, 302's, 351's, 460's with 100k, 200k, 300k miles on oil OTHER than AMSOIL, so I doubt his problem is directly related to what brand oil he or she is using.
Did you read the entire thread or just jump in for fun? I'm not buying $10 quart oil, especially since it isn't API certified. Guess I'll just stay stuck in the stone age.
  #56
Old 07-25-2014, 09:49 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
+1, this thread took a left turn right into an infomercial for motor oil, a bad one at that (is there any other kind?) ....amsoil the cure all for whatever ails it.... yea right......
I have zero problems and with the oil I have em put in at the oil and lube joint up the road. And no it isn't that oil and the oil it is doesn't cost anywhere near 10 bucks a pop.
  #57
Old 07-25-2014, 11:50 PM
LOL! you guys are always experts!
Data Finds 1 in 5 Bulk Motor Oils Fail to Meet Performance Standards
  #58
Old 07-25-2014, 11:55 PM
Why are you posting here? you don't have problems, and you are not adding anything to this except take it to jiffy lube!
This thread is for folks who work on their own trucks and learn from others.
We all watched TV and we all seen Jiffy lube commercials.
I offer up my experience and you offered up yours.
  #59
Old 07-26-2014, 12:29 AM
So if I spend 60 bucks on some Amsoil my oil comsumption will be greatly reduced or go away completely............
  #60
Old 07-26-2014, 12:34 AM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
This is getting too far off topic and has run it`s useful course.
Closed Thread
White exhaust smoke when letting off throttle balingwire 1999 - 2003 7.3L Power Stroke Diesel 15 07-09-2016 12:16 PM
06 5.4 burning through lots of oil Shrydo 2004 - 2008 F150 2 09-26-2015 11:35 PM
2003 PSD Using LOTS of Oil jjfl99psd4x4 1999 - 2003 7.3L Power Stroke Diesel 7 02-04-2015 10:39 PM
2004 5.4V Super Crew Oil leak penguinshockey 2004 - 2008 F150 1 09-05-2014 11:45 PM
High Oil Consumption at 1500 Macs1964F100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-31-2014 10:31 PM
Tags
150, 2003, 95, blowby, consumption, consumshion, diesel, engine, excessive, f350, ford, high, no, oil, smoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
