What all could cause a single cylinder misfire on the 4.0?
Old 10-25-2002, 05:51 PM
nittany's Avatar
nittany
nittany is offline
Hey Guys?
I have a 96 4.0 with 70K on. It recently started to misfire under load. The check engine light is telling me the #6 cylinder is misfiring. I changed the plugs and wires about 8K ago and it never misfired until a couple of weeks ago.I want to check if there might be a loose conection on one of the plug wires, but i'm not sure which cylinder is the sixth.
Let me know if any of you guys know what might be causing this. The only things I can think of are the loose plug wire or a clogged injector.
Thanks
Old 10-25-2002, 06:28 PM
Rand's Avatar
Rand
Rand is offline
What kind of plugs, My bosch plugs fouled out
about every 5-10k miles till i switched to autolite.
Rand
Old 10-25-2002, 09:08 PM
nittany's Avatar
nittany
nittany is offline
I put autolite plugs in it and bosch wires. I don't think its a fouled plug but its possible. Anyways, do you know how the cylinders are numbered.
Thanks
Old 10-25-2002, 10:04 PM
Ken00's Avatar
Ken00
Ken00 is offline
1-4-2-5-3-6. Have you tried switching the plug and wire to see if the miss moves? I also answered to your other post about the 4.0 intake leak that seems to be common to the 4.0. Just an FYI, a DIS ignition system should have double platinum plugs due to the positive/negitive firing.
Old 10-25-2002, 11:47 PM
redranger1's Avatar
redranger1
redranger1 is offline
it will certainly be one of the back cylinders, just not certain which one of the back 2. my guess would be on the pass side though.
-nathan
Old 11-05-2002, 06:52 PM
tkjay's Avatar
tkjay
tkjay is offline
I bet your valve seals are leaking possibly only in the #6 it happened to me with the # 4 fouling out
Old 11-06-2002, 03:29 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
A Hanes/Chilton manual for your truck would be a very wise investment.
From page 1-2 in a Hanes manual:
Engine cylinder numbering 3.0 and 4.0L V-6
3|6
2|5
1|4
Fan/front
Coil pack numbering 3.0 and 4.0L V-6 with distributorless ignition.
3-4
2-6
1-5
Front
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 11-06-2002, 06:02 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
NOWAYBUTUSA
05-16-2015 06:24 PM
cottonf150
1997 - 2003 F150
02-02-2015 09:53 PM
Larry72
1997-2006 Expedition & Navigator
12-20-2013 09:39 PM
Adam Hyer
1997 - 2003 F150
11-26-2013 11:04 AM
bronkntrukholik
07-17-2010 10:14 PM
Quick Reply: What all could cause a single cylinder misfire on the 4.0?
