ac /thumping noise - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
ac /thumping noise
Old 11-06-2002, 07:38 PM
jrush jrush is offline
jrush is starting off with a positive reputation.
ac /thumping noise
I have a 2000 xlt 4x4 Ranger. Since the day i purchased it every time the ac compressor kicks on i get a loud thump,the dealer has replaced the compressor accumalator and no change with the noise.they tellme its normal knowone else that i talk to seems to have this problem. Any help
Old 11-07-2002, 03:13 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
ac /thumping noise
Are the bolts holding the compressor tight? When the clutch engages it could be moving the compressor or its mounting. A mounting bracket could be broken also. A hose bracket could also be loose.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 11-07-2002, 08:20 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Post ac /thumping noise
If the gap on the clutch is too wide, the clutch can make a thump when it engages. The gap is generally about the thickness of a credit card. Did the dealercheck the gap or replace the clutch when they did the other parts? I'm making the assumption that this thump occurs at every speed, at idle and going down the road... Right? At idle, you can expect a slight thump as the compressor is engaged. At road speed, it would be an almost imperceptable hesitation.
If it were mine, I would demand to see another of the same model, at least the same engine-trans combination. Check how it worked, and if it was quiet, I'd politely point out that fact. In some states, a dealer has a certain number of allowed attempts to effect a repair before the vehicle is deemed to be a lemon, and then subject to repurchase by the dealer...
tom
Old 11-07-2002, 08:33 AM
Thumping noise from dash! davidstjohn1 Ranger & B-Series 84 03-12-2016 04:52 AM
6.0 thumping noise signatow 6.0L Power Stroke Diesel 7 05-30-2015 11:40 PM
Thumping During Turn (Problem Resolved) Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-11-2015 08:18 PM
clunking in 4WD pgguru Excursion - King of SUVs 3 12-11-2014 03:00 PM
Thumping Noise from front end (4WD) dutchnichols 1999 to 2016 Super Duty 8 09-26-2014 10:29 PM
Tags
07, ac, airconditioner, compressor, f150, ford, noise, sound, thumping, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
