Seam Sealer
I used an Eastwood product called seam sealer. It comes in a can and is applied with a cheap narrow throw away brush. Is flows nicely into the seams, dries in a few hours, has a smooth even paintable surface. Seems to me it was about $25 or $30 for a quart. That is enough to do a couple of complete vehicles anywhere two pieces of metal are welded together that will not be a class A painted outer finished surface.
I use a flexible silconized latex sealer. With any type of sealer the important thing is to make sure it is paintable. If you use plain silcone sealant the paint will not sick and it can cause fish eyes in the paint in areas surrounding the seams and places you might accidently touch. Also, some silicone sealant will rust steel. Make sure you read the label.
