Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
gas mileage 89 7.3 vs dodge 360 5.9
Old 11-01-2004, 11:37 PM
Fordfreak1978's Avatar
Fordfreak1978
Fordfreak1978 is offline
Which of the two trucks would get better gas milage an 89 7.3 or a 95 dodge ram 360 5.9l gaser, supposing they both are stock. Or what if the 89 had the 7.3 banks power
Old 11-01-2004, 11:50 PM
johnsdiesel's Avatar
johnsdiesel
johnsdiesel is offline
The 7.3 IDI will get better mileage. When I first saw 5.9 I assumed you were talking about a Cummins.
Old 11-01-2004, 11:55 PM
Fordfreak1978
hey thanks alot
Old 11-01-2004, 11:58 PM
BigDaddy6969's Avatar
BigDaddy6969
BigDaddy6969 is offline
7.3 IDI=Not real good mileage
5.9 Gasser= worse mileage
Personally i am not real big on the IDI motors.
Old 11-02-2004, 05:57 AM
351M's Avatar
351M
351M is offline
Well, I can tell you that the IDI will do better. Diesel is almost as much as Gas now, We have a Fullsize Dodge 15 pass. Van 5.9, 3.9 gears, 4 spd auto. My old man towed a loaded U-haul trailer to Manitoba, and figured the milage out to around 19 Mpg. (that was there and back not one way) The old '88 diesel we have supercab 1-ton dually 4:10 Limited slip, 2wd, C6 6.9 still runs every day for alot less then the van will and it gets about 15Mpg, go figure eh?
Old 11-02-2004, 09:21 AM
Big_Al59's Avatar
Big_Al59
Big_Al59 is offline
I had a 88 dodge 3/4 ton 4wd with a 360 4bbl, 4:10 gears and averaged around 12 mpg, I average 17 mpg with my 97 psd f250 4wd 4:10 gears.
Old 11-02-2004, 11:33 AM
Frost13's Avatar
Frost13
Frost13 is offline
the 360 will get horrible mileage
the 7.3 should get pretty good mileage
Old 11-02-2004, 11:35 AM
Frost13's Avatar
Frost13
Frost13 is offline
the 7.3 should get even better mileage after the banks stuff
jadel
38
02-01-2017 11:37 AM
DanielT28
06-15-2016 01:35 AM
johnwassink
20
09-05-2014 12:02 AM
true blue
18
12-18-2010 12:04 AM
LPD111
40
12-08-2003 11:46 AM
Quick Reply: gas mileage 89 7.3 vs dodge 360 5.9
