351M: big block or small block? - Ford Truck Enthusiasts Forums
Old 10-20-2004, 10:09 AM
Unwound Unwound is offline
Unwound is starting off with a positive reputation.
I have a 78 F250 with a 351M. Someone wants to pull the engine out and use it in his boat, but it'll only fit if it's a small block. Does anyone know if 351M's are small block or big block? Thanks.
Old 10-20-2004, 10:18 AM
firstonraceday's Avatar
firstonraceday firstonraceday is offline
firstonraceday is gaining momentum as a positive member of FTE.
Bill Beyer, moderator of the 335 series forum (351C, 351M/400) posted the following in the 335 series engine forum guidelines:
"Avoid speculation on whether the 351M/400 is a "big block" or "small block". These are generic terms which generally apply to Ch*vy motors not our beloved blue oval mills so they really have no place in this group. The 351M/400 has elements relating to both the 385 series and the Windsor series and attempting to categorize them is futile, especially when using monikers which FoMoCo never adopted."
FWIW, the bellhousing bolt pattern on the 351M is the same as the 429/460.
73Custom 73Custom is offline
73Custom is starting off with a positive reputation.
Well said Jason...
His boat must need a 289, 302, 351w or 351c.
Marty
Old 10-20-2004, 10:25 AM
So, it sounds like the 351M is on the bigger side, and if he's looking for a smaller V8 this one is probably too big? I suppose I could just get in there and actually measure the max height & width.
Old 10-20-2004, 10:36 AM
crack's Avatar
crack crack is offline
crack is starting off with a positive reputation.
but isnt a clevleand a "big block"
Old 10-20-2004, 10:58 AM
I'm assuming that with a boat, the main issue is the bellhousing bolt pattern. The drive system must've been made for a peticular motor. The 'small block' Ford pattern is the same for 289, 302, 351w and 351c - they all have the same bellhousing bolt pattern.
Marty
Old 10-20-2004, 11:26 AM
I don't think the bolt pattern is the issue. I think his concern was with the actual dimensions of the engine, that it would be too tall & wide.
Old 10-20-2004, 11:32 AM
7DF250 7DF250 is offline
7DF250 is starting off with a positive reputation.
I am by no means an expert but don't you think the 351M would make a really lousy boat motor anyway?
Old 10-20-2004, 11:46 AM
Lane Dexter's Avatar
Lane Dexter Lane Dexter is offline
Lane Dexter has a good reputation on FTE.Lane Dexter has a good reputation on FTE.Lane Dexter has a good reputation on FTE.
I would suggest a nice 302. Folks who swap V8's into old Scouts and such will tell you the little Ford is trimmer, an easier fit than the smallblock Chevy.
Old 10-20-2004, 12:28 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
This is an ENGINE Question not 73-79 truc k question
Old 10-20-2004, 12:39 PM
yep. sorry. i have a hard time not thinking of all my questions as 73-79 questions. i'll try to remember that next time.
Old 10-20-2004, 01:51 PM
Rancheroracer Rancheroracer is offline
Rancheroracer is starting off with a positive reputation.
Some engine dimensions: 221thru302: 24"w,29"Ln, 27.5"ht, 460 wt;
351w: 25"w, 29"Ln, 28.5"ht, 525 wt;
351C: 25.5"w,29"Ln, 29"ht, 550 wt;
351M-400: 26"wi, 29"Ln, 29"ht, 575 wt;
332-428: 27"w, 32"Ln, 29"ht, 625 wt.
Old 10-20-2004, 01:52 PM
Forgot the other "big block", 429-460: 27"w, 34"Ln, 29"ht, 720 wt
Old 10-20-2004, 02:53 PM
thanks Rancheroracer ! that's exactly what i needed.
Old 10-20-2004, 11:37 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
You can edit your own posts for up to an hour after you make them if you "forget" something...
Small Block or Big Block? TheDawnof68 1967 - 1972 F-100 & Larger F-Series Trucks 23 09-29-2014 08:07 PM
engine swaping jay64 New Member Introductions 3 02-13-2014 07:35 PM
351 big block or small block? 89ford73 1987 - 1996 F150 & Larger F-Series Trucks 6 09-15-2007 05:02 PM
351m or 400 Zachary Smith 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-29-2005 06:07 PM
C6 for 351 cleveland canadianfordman Clutch, Transmission, Differential, Axle & Transfer Case 7 05-10-2002 06:44 PM
Tags
1978, 1979, 351, 351m, 351m400, 79, big, block, bronco, f250, ford, motor, small, specs, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
