5.0L Vs. 4.6L !
Well...I'd say they're pretty even based on my experience of owning a 302 in my truck and being in a few 5.0 mustangs, 5.0 town cars/explorers and 4.6L mustangs/cougars/town cars.
The 302 has better low end torque, the 4.6 is more of a high reving high rpm horsepower motor. The 4.6L is a little more complicated being that they have overhead cams. The 5.0Ls are dirt cheap to repair/rebuild or modify for higher power. Both have about the same quality in longevity, the crown vic 4.6's have a rep of being good motors so if it passes the cop abuse it can handle anything you can throw at it. However...the 5.0L is a good performer in the longevity level as well....so off that, I'd say longevity is a tie. In the end...
If I had to decide I'd pick the 5.0 every time.
ive owned a 97 f-150 with the 4.6 and it was a good engine the person i sold it to said it turned over to 215,000 and still no problems, it had desent power.
i also have a 90 bronco with a 5.0 and it has about the same power but at a lower rpm and is alot easier to modify for more, with the bolt on power parts i can lite up the 37inch tires on the bronco it has close to 240,000 miles on the orignal engine
Originally Posted by buckeyebronco
What kind of mods have you done that you can lite up 37s? ive got a stock 5.0 rebuilt about 5000 miles ago and i cant even lite up my worn 31s.
all iam sayin is you can have all the power you want but if you cant put it to the wheels it dont do you no good
