C6 mods - Ford Truck Enthusiasts Forums
C6 mods
Old 10-19-2004, 02:45 PM
tastyklair tastyklair is offline
tastyklair is starting off with a positive reputation.
C6 mods
Has any one here done the upgrade to the Ford "C6 hd 6 pinion wide ratio gear set kit #M-7398-f". Was wondering what the results were of the upgrade.
Fuel pump upgrade? 74 F350 SCS 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-06-2012 06:13 PM
4.6 power upgrade andy 1979 2004 - 2008 F150 5 09-01-2010 12:13 PM
overdrive for 1977 C6 77finleyranger Clutch, Transmission, Differential, Axle & Transfer Case 2 06-16-2004 12:46 AM
C6 Transmission Cooler Upgrade SloWave Clutch, Transmission, Differential, Axle & Transfer Case 1 03-29-2002 03:32 AM
C6 Upgrade jalopy45 Clutch, Transmission, Differential, Axle & Transfer Case 4 02-09-2002 06:08 PM
Tags
c6, ford, m7398f, modifications, mods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
