1990 f250 2w drive lift kit, cant find one help!!!! - Ford Truck Enthusiasts Forums
Old 10-19-2004, 02:45 PM
yamaha4400 yamaha4400 is offline
yamaha4400 is starting off with a positive reputation.
I have a two wheel drive 1990 f250 and i was looking for a 4 or preferebly 6" lift can some one help me find one
Old 10-20-2004, 01:57 AM
Lane Dexter's Avatar
Lane Dexter Lane Dexter is offline
Lane Dexter has a good reputation on FTE.Lane Dexter has a good reputation on FTE.Lane Dexter has a good reputation on FTE.
I don't know of much lifting of two wheel drives going on. My guess is, you'll have to wing it. Manufacturers of suspension kits put their R&D and Marketing money where they perceive a Market. There's not much of a market for 2WD lift kits.
You'll do a lot of measuring and studying, hopefully with a suspension-savvy buddy. Then you may end up ordering suspension kit pieces by physical dimensions, rather than listed applications. After that, you'll likely end up fabricating a few parts (do GOOD work; your life rides on your suspension).
But I think you can do it, if you really want to.
Old 10-21-2004, 06:11 PM
murphco murphco is offline
murphco is starting off with a positive reputation.
camburg.com,fabtech.com,performancelifts.com.
Old 10-21-2004, 07:46 PM
351ballsofford 351ballsofford is offline
351ballsofford is starting off with a positive reputation.
lane no offense brotha but i just put a 4 inch lift on my truck which happens to be 4x4 and the lift that i put on my truck was for 4x4. i'm not saying this with attitude but there is more and more 2wd liftkits in the magazines lately.
Old 10-22-2004, 03:18 AM
Hey, no kidding? I guess I must be behind the times. If you just want the look, there's no reason not to lift a 2WD. I just figured it was pretty much a 4x4 market that went along with big off-road tires. If they are actually selling 2Wd lift kits, then someone must be buying them. Front suspension is a usually different on 2WD, so that may complicate the job a bit.
Personally, I don't expect to ever need a lift on my '77 2WD. I have 235/85R-16's on it now, and that's almost as tall as the 7.50-16's we ran years ago. I'm pretty sure my fenders would clear 255/85R-16 rubber if I wanted it. Just cannot see going taller than that on 2WD.
Old 10-22-2004, 11:23 AM
why cant you see going any taller?go to autofab.com and look at what john has been doing to that era truck for twenty plus years.16 inches of wheel travel in the front and 18 in the back.correct camber and caster,with a 33 or 35 inch tire.
Old 02-26-2014, 05:56 PM
svp_evo's Avatar
svp_evo svp_evo is offline
svp_evo is starting off with a positive reputation.
I know its an old thread, but its a new subject for me. The Original post was for an f250 wd. I looked at every recommended shop and they only carried bronco/f150. Are they that similar that these kits will work without compromise ? if so why wouldnt the manufacturer list them for f250s as well.
Old 10-27-2014, 06:20 PM
GreenMachinee's Avatar
GreenMachinee GreenMachinee is offline
GreenMachinee is starting off with a positive reputation.
Cool
Quote:
I have the same truck with the same damn problem. Looked everywhere!!!! But I can't find a kit for mime either.
1990 F250 XLT Lariat 7.5L 460
1990 f250 HELP zachbrown0413 1987 - 1996 F150 & Larger F-Series Trucks 4 06-05-2016 11:34 AM
Trying to find lift kit for my 1990 F 250 pigmanf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-09-2015 12:35 AM
lift or leveling kit?? 1990 F-250 XLT Lariat GreenMachinee 1987 - 1996 F150 & Larger F-Series Trucks 0 10-17-2014 02:50 PM
1990 F-250 TTB nordictom 1987 - 1996 F150 & Larger F-Series Trucks 8 05-29-2014 11:58 PM
1990 f250 lift 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 13 06-16-2013 11:14 PM
Tags
1990, 1996, 2w, 2wd, 90, camburg, diesel, drive, f150, f250, inch, kit, lift, lifting, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
