gages peg out - Ford Truck Enthusiasts Forums
gages peg out
Old 10-18-2004, 09:03 PM
doudavi doudavi is offline
doudavi is starting off with a positive reputation.
gages peg out
1999 F150 5.4 four wheel drive --when I crank the truck, for a few sec.'s the gages peg out to the right along with the speedometer then they return to normal--whats going on justed started doing this
Old 10-19-2004, 09:16 AM
luv_mud luv_mud is offline
luv_mud has a good reputation on FTE.luv_mud has a good reputation on FTE.
There is a TSB on this (#15219) and if memory serves me right when I inquired about my truck doing this, was told that it was just a normal self diagnostic check of the gauges and not to worry. It hasn't happened since I replaced the instrument cluster because of intermittent display problems so personally I'm not sure if the two are related or not. Try doing a site search ( right hand side of screen) on this topic as it has been mention before and maybe some one has more info on this. Hope this helps.
BTW Welcome to FTE.
Old 10-19-2004, 12:28 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Actually, it's a sign that the PCM is not receiving enough voltage from the truck's battery to retain it's settings after the truck has been turned off for awhile. 99% of the time, a weak battery is the cause.
Old 10-19-2004, 05:45 PM
thanks PaulC was hoping that might be the problem --the battery is a 99 also so off to the store i go thanks again doug
Old 10-20-2004, 02:03 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
Mine did that a couple of times and then the battery died.......check/replace your battery and use those felt washers and electrical grease stuff to keep a good connection.
Old 10-20-2004, 11:30 PM
F150ATM F150ATM is offline
F150ATM is starting off with a positive reputation.
Mine did the same thing 2 weeks ago when I ran the battery down while camping.
Tried starting the truck ('03 FX4) and the gauges pegged out, then click click click from the starter. Got a boost and everything has been OK ever since.
Based on the age of your truck I'd agree with Paul and Triton 2002 and go with a weak battery.
Hope this helps.
Mike
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
