Newbie ?'s about gear ratios and limited slip
Could someone point me to where I can get info. on gear ratios and limited slip? My husband and I are looking at a 2004 SCrew 4X4 with the 5.4. The one we're interested in includes the 3.55 ratio and the trailer tow package. What would the advantages be to having the limited slip or different gear ratio? How does the gear ratio affect your rpms while on the highway? Please forgive my newbie questions.
The lower your gear ratio the more rpm's you will turn on the highway.For example 3.73 will run at a higher rpm that 3.55 and with 3.73 you will be able to tow a little more weight.As far a limited slip's are concerned this device help's transfer power to both you back tire's instead of just one.A limited is deifnetly a plus.
d0n_3d
1983 - 2012 Ranger & B-Series
13
12-18-2003 04:23 PM
