Power Window - driver's side - not working 1999 F-150 Supercab - Ford Truck Enthusiasts Forums
Old 10-18-2004, 03:48 PM
manderson99 manderson99 is offline
manderson99 is starting off with a positive reputation.
Hello all,
I was hoping to search on this site and find a quick answer, but I can't seem to find a "search" feature for the forums!!! I just bought a used 1999 F-150 Supercab (V6) less than a month ago. As used, of course, I received no warranty of any kind. Yesterday, I found I could no longer roll down the driver's side power window. Whenever I push the button, it makes a clicking sound in the fuse box. The problem is, the fuse for the power windows covers both driver and passenger sides, but the passenger side works fine.
I did notice that there is a black plug called a Relay that affects the Auto Down power window feature. Since the driver's side is the only window with Auto Down, I'm hoping maybe that relay just needs replaced, and everything will magically work again??? I'm NOT a car/truck nut - I don't even know how to change my own oil.
I recently had a power window motor on my 1995 Thunderbird replaced at a cost of about $150. I'm hoping I don't have to do that already, just a month in to my F-150. But on my T-Bird, there was no clicking in the fuse box when I tried to window.
Any ideas would be most appreciated!!!
Mark A., in McKinney, TX
(Click Here to find out why email addresses are removed from posts.)
Old 10-18-2004, 11:07 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Open the door and have someone wiggle the wiring around in the door jamb while you work the switch. The wiring may have broke in that area.
Old 10-19-2004, 08:41 AM
guzzler96's Avatar
guzzler96 guzzler96 is offline
guzzler96 is starting off with a positive reputation.
Lightbulb
You say the clicking is coming from the fuse box?? I know on my '90 there is a set of nylon gears in the top end of the window motor. When the gears strip the window won't go up and down. It makes a clicking sound when the motor turns because there is sort of a cam and rollers in there. Took it to a local automotive glass man and he drilled out (3) holes in the door with a hole saw and then unbolted the motor. Replaced the nylon gear set and voila, the window works again. Charged me like $95 to do it. I have had to have both windows done in mine.
Just a thought,
guzzler96
Old 10-19-2004, 07:43 PM
Nascarfreak88 Nascarfreak88 is offline
Nascarfreak88 is starting off with a positive reputation.
I used to own a 1990 Toyota Camry that i had the same problem with. My passenger side windown wouldnt go down using either switch. I took the panel apart and used a cordless drill battery to crank the window down. then i hit the swithces and it would roll back up. "That odd?" i though, so i bought a master and a passenger window switches off of eBay and tried that. That didnt help. So it want a falty motor, or bad switches. A few days later, my driverside window quit working. I went to the toyota dealer, and they recomended that i check the wires that go beween the door. sure enough, i had a wire broken in both of the door jams.
here's a pic...
Old 11-16-2004, 11:46 AM
Dakrri's Avatar
Dakrri Dakrri is offline
Dakrri is starting off with a positive reputation.
I have the same problem on my 1999 F250. Somtimes the drivers side window works up and down and the next time it won't. However when it's doesnt work, I can always here a selinoid(??) clicking in by the fuse box.
The other 3 windows work fine. If its a loose/broken wire, why would you here the clicking noise?
dakrri
Old 11-16-2004, 02:00 PM
guzzler96's Avatar
Lightbulb
Don't know why you would. Take a look at this post and see if you think it makes sense for your problem??
http://www.ford-trucks.com/forums/sh...d.php?t=298012
guzzler96
Old 07-22-2012, 09:57 PM
rfsmith48 rfsmith48 is offline
rfsmith48 is starting off with a positive reputation.
No window function
you hear the relay cycling because it is upstream of the broken wire or broken window motor. (The relay delivers power to the regulator motor.)
Old 07-23-2012, 06:40 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Seriously, that was almost 8 years ago...
Old 10-17-2013, 04:43 PM
slamonte slamonte is offline
slamonte is starting off with a positive reputation.
Unhappy similar problem with my 1999 F250
I took the motor out of the door and noticed the motor would turn when pushing the button to roll up but does not turn when pushing the down/auto button. I'm not sure where to go from here. Switch problem or some kind of regulator upstream? Is there a wiring diagram I can grab online because now I have the door apart and I'd like to fix it today?
Old 10-17-2013, 07:22 PM
Franklin2's Avatar
You could look on autozone's site and see if they have a diagram for it. You have to register, plug in your truck, and then to vehicle repair guides.
Sounds like the switch to me. The motor runs in one direction, so it must be good. The switch swaps the polarity of the wires to the motor.
1999 power windows RSA7.3 Ranger & B-Series 5 01-08-2017 01:16 PM
96' F350 XLT Crew cab rear window problems cityjack 1987 - 1996 F150 & Larger F-Series Trucks 6 08-15-2016 08:45 PM
Power windows & door locks have suddenly quit working mrjimbov Electrical Systems/Wiring 7 11-23-2014 08:20 AM
F 350 drivers side power window problem poppop50 1999 to 2016 Super Duty 10 08-03-2013 06:32 PM
Power Window Stopped Working LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 03-26-2013 08:38 AM
Tags
1996, 1999, 250, 97, clicks, driver, driverside, expedition, f150, ford, fuse, inoperative, navigator, passenger, relay, side, window, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
