tire rotation pattern - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-10-2002, 08:39 AM
Ranger98 Ranger98 is offline
Ranger98 is starting off with a positive reputation.
What's the pattern for rotating tires on a 4x4? The Haynes manual I have says RR-RF, LR-LF. I thought with a 4x4 you'd have to X them? ex. LF-RR, RF-LR. Is that right? And it's a 4 tire rotation, no matching spare.
Old 12-10-2002, 09:47 AM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
front to back and criss cross are both acceptable for most tire manufacturers on 4wd systems.
Personally I'd criss-cross them.
Old 12-10-2002, 11:45 AM
Thanks, Super
Old 12-10-2002, 03:48 PM
mathelm's Avatar
mathelm mathelm is offline
mathelm is starting off with a positive reputation.
If you do the X swap, won't this change the direction the tire is rolling? I have always heard that was a big no no with radials. Unless your talkin about havin the tires remounted, which would be way too much for helpin tire ware.
Old 12-10-2002, 04:13 PM
Rand Rand is offline
Rand is starting off with a positive reputation.
I would just go front to back.. if you X then you will get a buttload of noise and vibration sometimes.. esp. if you dont rotate like every 5000 miles (less on aggressive tires)
Rand
Old 12-10-2002, 06:19 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
front to back and criss-cross works for me. I do that on all tires I have except mud tires.
Old 12-10-2002, 09:20 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
I always go front to back, never X. I did that X a couple of times and ended up with belt shifts and strange wear patterns. I think the manufacturers just like to sell tires. On a TIB front end I would swap the tires on the rims to help with the outer edge chopping. You can't go wrong with front to back so why take a chance? A good low mile spare can be traded in after a couple sets of tires to a dealer for replacement use.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 12-11-2002, 07:51 AM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
I might be ****, but I do it just like the owners manual says. Front tires cross over onto the back and back tire move straight to the front. I have always used this pattern about every 5,000 miles and typically I get 75,000 miles out of a set of OEM tires before I replace them.
Old 12-11-2002, 12:45 PM
wolf513 wolf513 is offline
wolf513 is starting off with a positive reputation.
I agree with ranger pat. I've followed the owners manual and haven't had any problems. And I am currently on my second ranger.
Old 12-12-2002, 08:32 AM
so it's almost a half and half of the two methods. i got it.
what I don't have is the owner's manual....bought used and never got it. I have a Haynes manual, but it only gives the front to back and only talks about 4x2's...not 4x4's.
I'll go with the manual.
Old 12-12-2002, 02:32 PM
mathelm's Avatar
87 Ranger 4X4 Owners Manual....
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=11217&.jpg
Old 12-13-2002, 01:06 AM
Torque1st's Avatar
Posting Legend
It lists rotation patterns just like those above in my owners manual also. I am just overly **** and use the 4 tire front back method pictured in the manual. I have received 70,000 miles out of a set of Firestone FR480's on a fullsize Ford van with tire rubber to spare, now that's impressive. I changed them out just to have more rubber for the winter. I probably could have got another 10-15,000 out b4 the wear bars were showing.
Old 12-13-2002, 06:40 AM
ranger pat's Avatar
Newer owners manuals only show 4 and 5 tire cross rotation instead of both cross and front to back.
Old 12-13-2002, 07:34 AM
mathelm's Avatar
Haven't ya figured out yet that they don't know. Lawyers wrote the manual. So just put your front tires on the back, and your back tires on the front, repeat as necessary. And when ya switch brands of tires, hang your spare from a rope in a tree so the kids can swing on it.
Lifes short, enjoy your truck. Just drive....
Old 12-13-2002, 08:18 AM
I did it..front cross to back, back straight to front..a little more road noise and a little more vibration....but they'll be alright in a couple hundred miles.
Trying to get it set up right this time Vwags Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 41 07-23-2015 09:55 AM
New TPMS sensor won't reset. sgtscrounge Explorer, Sport Trac, Mountaineer & Aviator 0 03-06-2014 07:37 PM
Excursion steering loose AFTER new tires and Ford alignment jlwpapa Excursion - King of SUVs 9 07-06-2013 01:19 PM
1993 E350 with rear abs forddriverdad 1968-2013 Full Size Vans 4 06-28-2012 07:11 PM
RF brake grabs harder mizzitch 1999 to 2016 Super Duty 2 10-23-2007 01:25 PM
Tags
2002, 4x4, 4x4s, f250, ford, fordrangertirerotationpatern, forums, pattern, ranger, ronger, rotaion, rotation, tire, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
