Door lock diagram - Ford Truck Enthusiasts Forums
Door lock diagram
Old 10-18-2004, 12:02 PM
flairside-ut5 flairside-ut5 is offline
flairside-ut5 is starting off with a positive reputation.
Door lock diagram
For a 1995 Ford F150 - does anyone have a diagram of the connection between the door lock cylinder and the lock? The power lock still works, but the key lock is disconnected. There is a curved rod connected to the lock, but it is just dangling loose on the other end, and I suspect there is some kind of connector to attach to the lock cylinder.
Thanks for any help.
Old 10-18-2004, 03:39 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
did you look in the crap at the bottom of the door? that is where the clip probably is.
or, take off other door panel to identify part.
or, go to advance or napa or any auto parts store and see if they have one.
or, got o ford and just get the diagram and part and be done with it.
good luck.
Door lock question janschutz 1957 - 1960 F100 & Larger F-Series Trucks 4 06-23-2015 06:02 PM
99 Navigator door lock cylinder Calgary Ole 1997-2006 Expedition & Navigator 10 12-31-2014 01:11 AM
What are the wires on the door lock cylinder for? (97 Ranger) Bob K. Ranger & B-Series 5 10-23-2013 09:33 PM
2000 Explorer manual drivers front door lock problems TJ Johnson Explorer, Sport Trac, Mountaineer & Aviator 4 07-22-2013 07:25 PM
1949 F1 Door Lock walt460 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 01-01-2009 10:03 PM
Tags
1996, 2003, 2004, 2005, 2006, auto, diagram, door, f, f150, ford, lock, power, series, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
