370 firing order - Ford Truck Enthusiasts Forums
370 firing order
Old 10-17-2004, 04:55 PM
bgss bgss is offline
bgss is starting off with a positive reputation.
370 firing order
I am working on a 1969 ford big truck with a 370. and i need to know the fireing order can antone please help? which cyl in is # 1?
Old 10-17-2004, 05:16 PM
Loan Ranger Loan Ranger is offline
Loan Ranger is starting off with a positive reputation.
The firing order of a 370 CID Ford engine is: 1-5-4-2-6-3-7-8. Cylinder #1 is the front cylinder on the right--passenger--side cylinder head. The right head is numbered 1-2-3-4. The left--driver--side head is numbered 5-6-7-8. The distributor rotates counterclockwise.
How did your 69 wind up with a 370 in it, by the way?
I hope this is of help to you!
Old 10-17-2004, 08:04 PM
Thanks.
The truck just came with it.
Old 10-17-2004, 08:38 PM
2Wise4aGM 2Wise4aGM is offline
2Wise4aGM is starting off with a positive reputation.
You sure its a 370?
Old 10-17-2004, 09:32 PM
yes that is what it says. It is about a 2ton truck.
Old 10-18-2004, 08:45 PM
ML1983 ML1983 is offline
ML1983 is starting off with a positive reputation.
As far as I know the 370 V-8 didn't become available until 1979. It's not impossible for your truck to have had the engine swapped to a 370, but the gas engine options for 1969 should have been the 330, 361 or 391 V-8s.
Old 10-18-2004, 09:29 PM
ML1983's post is valid. The 330, 361, and 391 are FT engines--medium-duty versions of the FE blocks. If you please, check for two things: (1) Does the intake manifold flanges go UNDER the upper edges of the valve covers? (2) Is the water pump bolted to the front of the block by four bolts--two per side--quite similar to a small- or big-block Chevrolet? Too, does it have 13/16th's hex spark plugs with an 18mm thread? These are all characteristics of the FE and FT engines. Admittedly, someone may have put a 370 in the truck; but they weren't built until 79--it is a version of the Lima block (370, 429, 460).
Needless to say, the tune-up specifications are different for a 370 and an FT engine.
If you please, do look into this! That is why, in my post earlier--#2 in this thread--I asked how you wound up with a 370 in a 69 truck. I was NOT trying to be a smart-mouth; rather, I was just trying to ensure you did have a 370.
Old 10-18-2004, 09:43 PM
If you do actually have an FT engine, the firing order for it is 1-5-4-2-6-3-7-8. The right bank is 1-2-3-4. The left bank is 5-6-7-8. It is timed at 6* BTDC. I hope this will be of some help to you, bgss!!
Old 10-19-2004, 08:38 AM
Question 370
I was in error when I wrote 69 it is a 79 ford truck. I hope this makes more sense.
The reason I installed a new dist. was I am not getting fire. I installed a new brain and the coil does have +&- power. I am at a loss. any Ideas.
Thanks
Old 10-19-2004, 06:24 PM
Make sure you are getting power to the module. Check the plug with the red and white wires. One wire should be hot in the start position and the other one should be hot in the run position.
Old 10-25-2004, 12:25 PM
What engine would be a easy replacement for the 370. Something that that there are plenty of.
Thanks
Old 10-25-2004, 03:27 PM
Of the 385-series engines (370, 429, 460), the 460 is the most-plentiful and the least expensive out of the series. Further, with gas prices going upward, it should make the 460 even cheaper due to supply and demand. Plus, if you wish to modify the engine to any degree, there is a plethora of parts for the 460's.
Old 10-29-2004, 12:13 PM
Bobber72 Bobber72 is offline
Bobber72 is starting off with a positive reputation.
How about this idea?
One of my Buddy's has an early 80's dump truck with a 370 in it. Unfortunately, he blew the engine, and pieces came through the oil pan. I was wondering if perhaps a 429 or a 460 would allow for the cam and heads off a 370 would give the larger engines more torque due to the smaller valves and the torqueier cam. What is y'alls opinion on this idea?
370 Oil Pan BADDBOYY21 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 04-15-2014 12:09 PM
Wrong firing order?? 370 4v earthman 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-19-2011 02:21 PM
370-4v specs 1979ford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 06-21-2011 01:36 AM
my 370 is backfiring mxzriderus 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-30-2010 06:04 PM
370 firing order 370man Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-17-2003 02:11 PM
Tags
361, 370, 370v, 429, 87, cid, engine, firing, ford, order, specifications, specs, truck, tune, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
