1996 Ranger Hubs
1996 Ranger Hubs
Hi I am trying to figure out what makes the front Auto hubs engage/disengage. There are no wire/hoses that go to the hub assembly itself. don't see any metal particles in the grease. Does someone have a picture of the inside of hubs in good condition? The complaint is when in sand and 4H or 4L the front wheels make a slamming noise with a little gas like their trying to engage. I thougt maybe was the relay. It tested ok. Where is the actuator for the hubs? Thanks
Your front hubs are engaged from the front axles rotating after the 4WD is selected. There are cams inside the hub that will rotate when the axles start to rotate. This brings the parts of the outer hub into contact with the axles and you are in 4WD. There is no other activation system on the stock setup. They should not bang into lock. Be sure that the transfer case is shifting. If it is not shifting, then the motor on the rear of the transfer case may be bad. It is not hard to get to. The hubs are easy to work on. Mine were not working proper and all I had to do was disassemble and clean. Then lube properly. The lube is where a lot of problem start. Then it is lack of use so that forces you to go playing more often. Gotta keep the hubs working. Get a manual and follow it.
The best thing to do is put on manual locking hubs. This way, you know they are locked. It is just a $200 expense and not hard to do. I just have not wanted to spend the money yet but I will some day. Hopefully before they break when I need 4WD.
Az Pete
Az Pete
Qustion...when you intall manual locking hubs do you have to still hit the selector in the cab after you lock them manually? Or will they just be engaged from when you do that? Just wondering, if you could put manual lockers on and leave them in lock w/o actually being in 4x4. So that all you would have to do is switch the selector.
The manual locking hubs must be rotated at the axle to lock, then you switch to 4WD inside the cab. Yes, you could just leave them locked all the time but it will make a big difference on your gas mileage and it will cause excessive wear on the entire front end. When locked, the entire front axle set will be turning all the time. I do not recommend locking them all the time. What I have done on other 4X4's I have had is to lock them prior to leaving the house when I know I am just a short way to the off road area. Once there, I then can shift in and out of 4WD as needed.
Az Pete
Az Pete
Az Pete
Az Pete
97 Ranger
Az Pete
Az Pete
You seem knowlagable in 4x4. My question is on a 97 Ranger with the typical compliant of noise when disengaging:
Better to service or replace? If replacement is the answer, can they be purchased aftermarket (auto lockers) or are they DIO?
I would first do a service on them, either auto or manual. Autos are expensive to replace and repair. Manuals run about $200 for replacing the old autos. The new autos are about $600 from Ford, the only source I know of. Not sure when Ford changed the hubs from the style on my '96. Manual hubs may not be available for your application.
Az. Pete
Az. Pete
manual hubs
just had manual hubs installed. Ford wanted $800-900 to fix ONE manual hub...had 4 wheel parts install manuals for $350 out the door. I haven't had a chance to off road yet, but I tested them out to make sure thy work. I think this slight hassle of having to get out of the car is worth it.
Pat
correction
what I should have written was that I had manual hubs installed because for wanted $800-$900 to fix one AUTO hub...forget that. The mechanic i talked too had an older broncoII, and said the problem on my car (or his, I forget now, it's been a few months) was a very small part, but you can't buy just that part, you have to buy the whole hub assembly. Knowing that manuals were pretty cheap, I stopped listening when he said "800 or so for one hub"...
buckskin charley
1999 to 2016 Super Duty
06-13-2009 12:22 PM
