Ford Radio Wiring Diagram - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 10-17-2004, 06:20 AM
ggnmb ggnmb is offline
ggnmb is starting off with a positive reputation.
Unhappy Ford Radio Wiring Diagram
Hello All - new member and need help right off - can anyone tell me what color ford radio wires are (what colors are what)? It is a oem ford radio am/fm/cassette - appreciate any help anyone can give
Old 10-17-2004, 07:56 AM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
I think that this should cover 86-on. I couldn't find one for the early type 2 Bronco. Let me know if you need that and I will dig deeper.
1986 Ford Bronco (fullsize) Stereo Information
Constant 12V+ Light Green
Switched 12V+ Yellow/Black
Ground Black/White
Illumination Blue/Brown
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Green
Left Front (-) Black/White
Right Front (+) White/Red
Right Front (-) Black/White
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Pink/Red
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-)
1989-91 Ford Bronco (fullsize) Stereo Information
Constant 12V+ Green/Yellow
Ground Red or Black
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Left Front (+) Orange/Green
Right Front (+) White/Green
Left Rear (+) Pink/Green
Right Rear (-) Green/Orange
1992-93 Ford Bronco (fullsize) Stereo Information
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Old 10-17-2004, 08:04 AM
JBronco's Avatar
Here's an 80-80 F-series truck diagram
1980-81 Ford F Series Stereo Information
Ground Chassis
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 5 1/4" Doors
Rear Speakers 6" x 9" Rear Corners
Left Rear (+) n/a
Left Rear (-) n/a
Right Rear (+) n/a
Right Rear (-) n/a
Old 10-17-2004, 10:19 AM
WhlM1's Avatar
WhlM1 WhlM1 is offline
WhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant future
Old 10-18-2004, 05:04 AM
GOT IT!!!! THANK YOU VERY MUCH - ESPECIALLY JBronco
Old 10-18-2004, 05:17 AM
JBronco's Avatar
Quote:
No problem, I'm glad that you got it hooked up!
Old 10-18-2004, 05:54 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Did you cut the harness, or did the PO? It's far easier to spend the ten bucks for an adapter.
Old 10-18-2004, 08:09 AM
We rewired the radio - was a job - should have got the "adapter" - thanks for asking
Old 09-02-2009, 02:54 PM
spininspur's Avatar
spininspur spininspur is offline
spininspur is starting off with a positive reputation.
stereo wiring
Quote:
I am replacingl the radio in my 86 f150. what could the blue/red be for the rest is already wired? Maybe illumination?
Ground Black/White
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Right Rear (-)
Ground Red or Black
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Old 12-25-2012, 09:52 PM
duckettcharlie duckettcharlie is offline
duckettcharlie is starting off with a positive reputation.
Exclamation Radio Problem
I have a 1990 F-250 Custom, its my understanding that the diagram works for both. The big problem i am having is that the AV Constant power does not stay on. I am trying to install an new radio due to the AM/FM not working, display not working and the tape playing sometimes not working. So I would really appreciate it if anyone knew a fix for both or either.
Old 04-10-2014, 01:28 PM
Jwetzel181 Jwetzel181 is offline
Jwetzel181 is starting off with a positive reputation.
Ground Black/White
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Right Rear (-)
Ground Red or Black
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Does anyone know what colors the wires for a stereo are on a 79 ford bronco. I am wanting to put a aftermarket stereo in it, and was wondering how to hook it up. From what i read ill have to hook the wires up with connectors and modify the heat control bracket in order for the unit to fit in. I was just wondering how to hook the wires up though. Thanks.
2005 Ford F-350 radio wiring jasonlee232 1999 to 2016 Super Duty 22 01-18-2016 09:54 AM
Back Up Camera LB2536 Large Truck 0 08-17-2014 11:30 AM
84 Factory radio wire colors/diagram needed CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-17-2012 12:23 PM
No Radio Wiring!!??? mdr617 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-18-2010 10:12 AM
Radio Wiring Vaokie1 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-23-2010 07:58 PM
Tags
1979, 1980, 1989, 1990, 1991, bronco, diagram, diagrams, ford, radio, stereo, stock, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
