Alberta Chapter Join Chapter, Leader: Puddy
rear bearing check and steering adjustment
Old 10-16-2004, 08:32 PM
twinanchor's Avatar
twinanchor
twinanchor is offline
Looking for someone that knows what to look for when checking rear bearings on big bronco or 1/2 ton . how much lateral movement of axle is allowed? up and down movement? etc. also what is the quick way of adjusting power steering box? thanks
Old 10-16-2004, 09:29 PM
mustange70's Avatar
mustange70
mustange70 is offline
For the bearings there should be mimal to no movement and if there was this would indicate wear problems, as for the steering i wouldn't be able to tell you but if you go and check in the forum that your truck is located in you should be able to get somehelp on that one.
Old 10-16-2004, 09:40 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Tech questions are best placed in the tech forums.,
This thread will be moved to the Drivetrain forum
Tparkin99
18
02-13-2022 06:28 AM
19tanker
08-17-2015 04:21 PM
Stanislaw
1997-2006 Expedition & Navigator
38
04-23-2015 01:48 PM
maverick600
01-06-2014 12:11 AM
shad44
1983 - 2012 Ranger & B-Series
22
06-16-2012 07:23 AM
Quick Reply: rear bearing check and steering adjustment
