Air Lift
Air Lift
Well as I stated in my "Brake Controller" post. The first time I tied onto the trailer Thursday night I watched the *** end drop about 2". Then Friday I went and loaded my boss's tractor on it and WOW did it sag. Dang sure ain't my Superduty. It didn't squat 2" with trailer and tractor, yes I have hauled it several times. So I went and got my AirLift set-up with on-board air Friday. Got busy at work Friday so I haven't had a chance to install it yet, but I'm sure the bags will do the trick.
Question now is, Anyone else running helper bags on their '04? And do you have the on-board air set-up? And if so, Where you mount the controls/gauge?
Shane
Shane
Well I put the Daystar 2.5" leveling kit in mine and it sits level. So when I hook the trailer up it sags that 2"-2.5". Ford thought that out well....lol. I tow whatever I need to. I am always hauling stuff all the time. May be a car, may be a truck, or just stuff in the bed. (Engines, trannys, etc.)
Shane
Shane
i think i paid 240.00 for the set i ran the air fittings into the lower license plate holes and put chrome caps on them then i got a 12v air compressor very small an d put a trailer plug on it so when i fill them it is right there pretty slick looks awesome coming down the road level towing a bob cat
I paid $180 for the bags and $125 for the on-board air. I haven't installed it yet, as I've been busy at work and doing some heavy yard work at home. So hopefully sometime this week I'll get it all on. Still undecided where I'm gonna mount the on-board controls/gauge. Not much room on the dash on these things if you have the flow through console. Still in that same boat on my brake controller as well. I can't find a good place that's out of my way.
Shane
Shane
Shan2,
whats the brand is on board air you have?
Is it like QUick air 2 or 3? ARB air compressor ??
I m thinking about get QA2 or 3 with a tank for air tools or fill up the tires after beach..
I used to have on board air on my jeep and it runs air tools, fill up tires its awesome but i sold it
Check this out www onboardair com
YOMAN!
YOMAN!
I'm looking into a toy hauler. My 04' has a 6" suspension lift and I hooked on to my friends to see the sag. Wow! Five inches! The hitch weight is 1200lbs (8000lb trailer)
He pulls it with a 2500HD with air bags. The trailer I'm looking at has a hitch weight of 1000lbs the Air lift set up says it will provide 2000lbs of lift so in theory with the bags I should have no problem, but five inches was a big suprise. Does any one have some real world experience with these bags in regards to hitch weight?
Mike
Mike
