Harmonic Balancer Question - Ford Truck Enthusiasts Forums
Old 10-16-2004, 06:24 PM
rrsandifer rrsandifer is offline
rrsandifer is starting off with a positive reputation.
Hi all, I hope someone can help me out. I have a 97 Ford ranger 2.3L that i am trying to replace the timing belt. I have removed the harmonic blancer bolt and im trying to get the darn thing off. It looks as if the serpitine pully and the harmonic blancer assy is one piece. The only problem is there are no bolt holes in the pulley to pull the assy off. Can someone please give me some advice on this thanks and have a good day.
Old 10-16-2004, 07:15 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Aren't there 4 bolts going thru the serpintine pulley into the balancer??? These hold the
pulley on the cast balancer. You can then use a balancer puller into those holes.
Old 10-16-2004, 07:26 PM
Hi,The only bolt is the center bolt that holds the whole assy on. Inside the serpitine pully it is tapered. NO other bolt holes to be found inside.
Old 10-18-2004, 05:55 PM
FordF150Fixer FordF150Fixer is offline
FordF150Fixer is starting off with a positive reputation.
Rrsadiler; I recently had the same problem with my '96 2.3. Several forum users kept advising me that the damper had tapped holes and to use a regular damper puller. Like yours, mine does not have any holes other than the large one in the center. I went to Sears and bought a gear puller. Sears sells several sizes of gear pullers. You will need the large one. I think it handles up to eight inch gears. The large puller was able to grasp the outer edge of the damper. The good part is that it didn't take much pressure from the puller before the damper/pulley popped right off the shaft. The bad part is that you may have to pull the radiator because of the length of the puller bolt.
Good Luck, hope this helps
Old 10-18-2004, 06:01 PM
hotrodfeguy's Avatar
hotrodfeguy hotrodfeguy is offline
hotrodfeguy is starting off with a positive reputation.
I just use two pry bars and wiggle it off.Unless they are really rusted on they come right off.
Old 10-18-2004, 09:25 PM
Thanks fellows, I went down and bought a six inch gear puller and it came right off. Keep them motors running.
Old 05-28-2005, 10:07 PM
moochy1 moochy1 is offline
moochy1 is starting off with a positive reputation.
Smile Damper pulley
Ford has a special puller for these no bolt dampers 150.00 plus tax, I hope this works for me. I sure heck will give it a try thanks Guys I had just about purchased that exspensive bolt and nut looking tool. Thanks again to all
Old 05-30-2005, 09:27 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome moochy1, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
torque values and harmonic balancer seal JRS2 1987 - 1996 F150 & Larger F-Series Trucks 1 04-15-2014 09:57 PM
HELP, torque spec. kevincw Explorer, Sport Trac, Mountaineer & Aviator 1 12-12-2008 09:47 AM
help me please oldbad69 1967 - 1972 F-100 & Larger F-Series Trucks 23 07-15-2005 08:31 PM
One more question about harmonic balancers FlooredMazda Ranger & B-Series 5 01-05-2005 08:32 PM
400 Harmonic Balancer/Crakshaft Bolt urif250 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 05-31-2002 09:15 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, 73, 97, balancer, diesel, engine, excursion, ford, harmomic, harmonic, plow, pull, puller, pulley, ranger, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
