Engine replacement on E150 Van - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-16-2004, 01:24 AM
Dannym Dannym is offline
Dannym is starting off with a positive reputation.
I am seriously considering swapping my 302 for a 351w in my '87 Ford E150 van. I am considering the compatability issues in another forum.
Here, my question is- how DO you pull the engine if you do not have a lift? I've got access to a hoist, but obviously this engine drops down below. Does a hoist even work here? There is no lifting room above the engine. How you lift & drop it? Some kind of jack or what? How much does the van need to be lifted to allow the engine to slide out from underneath? I can already see just how bad it would be to have it driven up on ramps and find it needs another inch to slide the engine away once it's dropped.
Old 10-16-2004, 02:42 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
remove the front clip
Old 10-16-2004, 04:09 AM
nightowl_52's Avatar
nightowl_52 nightowl_52 is offline
nightowl_52 is starting off with a positive reputation.
I don't want to be a naysayer but unless that 302 is in really bad shape, I can't see the advantage of going through all that work swapping it for a 351. You obviously have no idea what a job it is doing a shade tree engine swap on a van. I've done them, and I would rather do four swaps on a pick up, then one on a van. If your just looking to get a little more Wheaties out of your ride and the 302 is fairly sound, you should consider just doing some mods on that motor.
Old 10-16-2004, 04:51 AM
Quote:
I'm well aware of it. In fact, the cost of doing the leaking valve cover gaskets alone is half the cost of the new engine! Putting in serious mods (not bolt on crap) in that little cavity is just as hard as the engine swap. The 302 hp is bad- really bad (<10mpg highway)- and it guzzles a lot of gas since it spends most of the time in second just to keep up. It's not in bad shape, but an '87 with 130k on it it's not a spring chicken. I have a trailer I need to tow from time to time and it's just short of being dangerously slow. I've done all the junk on front at one time or another, researched what has to change to make a 351w match up, and it makes a lot of sense.
So, back to the question- just how DO you shade tree that engine into place?
Old 10-16-2004, 07:49 AM
76 maverick's Avatar
76 maverick 76 maverick is offline
76 maverick is starting off with a positive reputation.
Sounds like there is something wrong with you`r 302 . I hauled my 3,300 lb maverick on a dual axel trailor in overdrive (4th gear on an AOD tranny) with my mothers 1985 E150 302/aod @ 70 mph (down shifted to 3 gear and slowed to ~ 60 - 50 depending on the size of the hill) over 200 miles no prob. When its towing the boat it will go over 90 mph (*oops I didn`t mean to go that fast) and if I`m driving sane it will get 17 mpg easy .
Old 10-17-2004, 04:31 AM
You need to either get the Chilton or Hayne's book for that van, or go to the library and check out one of the big books for it. In them it should explain in detail how to remove and install the engines in that van.
It's a little too involved for someone here to explain everything that has to be done. Another thing you could try is to go to a local junk yard and see if you can talk to one of the parts puller guys and ask them what is the best way to remove those engines. When your ready to reinstall, just do everything in reverse.
Old 10-17-2004, 04:47 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
Im guessing that the 86 is similar to my 79. In that case it really wasnt that much of a chore as Id been expecting.
Once you strip the grille, splash apron, bumper and radiator the front is wide open. Everything unbolts, no Sawzall needed as on some makes.
I removed the carb, in your case that may be FI, but the principle is the same. Buy or build a lifting plate that bolts to the intake. The one I use has predrilled holes to mate up to about aything.
My hoist is too tall to go in straight so I changed the lifting chain to only 2 links and a hook.
Lift enough to remove the mounts, also remove the exhaust maifolds in an earlier step. The less clutter the easier it is to maneuver. Leave the tranny untouched but place a jack under it to support the weight.
Once the tranny bolts are removed then slowly lift a little bit and pull the hoist back a few inches at a time. You want to clear the torque converter without hittig it (Of course you had to remove the TQ to flex plate bolts!)
Im just hitting some of the spots here, but once the engine & tranny are seperated it is a matter of lifting and pulling back; repeating as necessary until you are clear.
I did the swap all by myself over a period of 4 days but a lot of that was cleaing up the engine compartment, painting things and generally just working a few hours at a stretch in between other chores. Also did things like clean the pan and screen of the donor 351W as well as change fluid in tranny and TQ.
Get the Haynes manual, it is excellent.
Old 10-19-2004, 11:57 PM
76... 87... when did Ford actually change anything?
Actually I checked both Haynes AND Chilton's. They described removing the grill, accessories, etc and then both simply said "Remove the engine". Unbolting stuff wasn't the mystery, it was that "Remove the Engine" that needed some elaboration, being several hundred pounds of unhoistable mass that would be most easily managed with The Force but I am not a Jedi... at least I don't believe I am. Much to my dismay, it appears I will need to open and refill the AC system... major bummer.
286merc, is that lifting plate a standard item? Just an extension for a hydraulic engine hoist? Do you mean I need to remove the intake manifold and bolt the lifting plate in its place, or are there exposed bolts holes on the intake, or are you describing wrapping something around the intake manifold?
Old 10-20-2004, 03:56 AM
This is a lift plate for a carbed engin ...
Old 10-20-2004, 03:57 AM
and this is one for an EFI engin...
Old 10-20-2004, 03:59 AM
But I like to use a load leveler when I can ...
Old 10-21-2004, 03:22 PM
Mustang 5.0's Avatar
Mustang 5.0 Mustang 5.0 is offline
Mustang 5.0 is starting off with a positive reputation.
I put the 351 in my 89 E-150 when I took out the 302. Well worth the extra grunt.
Old 10-21-2004, 03:32 PM
86rustbucket's Avatar
86rustbucket 86rustbucket is offline
86rustbucket is starting off with a positive reputation.
I remember the Chilton manual calling for you to remove the upper intake to gain clearance between the top of the engine and the firewall cavity. This also gives you a place to bolt the lifiting plate to.
Probably not the best method for removing an engine, but it seemed to work, was on Monster Garage a few months ago when they made a wheelstanding Ford van ambulance. If I remember right, they basically did what Ford390gashog said and removed most of the front clip.
Old 10-21-2004, 06:07 PM
Removing the carb gave me plenty of clearance to get in with the shortened chain/hook. Absolutely no room for a load leveler as pictured tho.
There are some lower profile hoists available but I used my old trusty 4 ton folding job with 8 ton ram that I got off Ebay from a tool wholesaler a few towns away.
Engine Hoist? Plan 'A' failed, what's Plan 'B'? taneum 1973 - 1979 F-100 & Larger F-Series Trucks 41 03-30-2013 02:30 PM
Assistance needed in removing oil pan 302 engine TruckDoggy 1987 - 1996 F150 & Larger F-Series Trucks 6 08-06-2012 07:57 PM
Home made jib crane 59INA40 Garage & Workshop 8 10-09-2009 02:40 PM
How do you attach your engine hoist bigblack302 1987 - 1996 F150 & Larger F-Series Trucks 7 02-04-2008 06:10 PM
Econoline Body R&R Questions davidh 1968-2013 Full Size Vans 9 06-28-2007 12:04 PM
Tags
351, 95, book, e150, engine, ford, hours, install, lifting, mods, plate, pulling, removal, remove, replace, replacement, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
